Wayne Gardner tribute {not replica}
  • kzstreetfighter71
  • kzstreetfighter71's Avatar
  • Atlantic West Coast
Re: Wayne Gardner tribute {not replica}
10 Jan 2022 06:28 - 10 Jan 2022 06:28
#860319
Sorry meant to include the chamfer on the outside edge.
Last edit: 10 Jan 2022 06:28 by kzstreetfighter71.
  • kzstreetfighter71
10 Jan 2022 11:43 - 10 Jan 2022 11:43
#860353
Just a little work on the under side to allow for a gasket, the walls a still 5mm thick which should be plenty.
Last edit: 10 Jan 2022 11:43 by kzstreetfighter71.
  • 750 R1
  • 750 R1's Avatar Topic Author
10 Jan 2022 15:38
#860371
That's cool, pretty good considering I only gave you 2 measurements. The caps are aircraft style, they are in the mail so I won't be able to get good measurements until they arive, they will need an inner lip/ledge to bolt to.  These are the only measurements they had on the site.
  • 750 R1
10 Jan 2022 15:42 - 10 Jan 2022 23:01
#860372
The two "tubes"/holes for the caps don't need to be too deep, just deep and thick enough to bolt the cap to. I'll PM you my email, actually, I think you already have it, let me know if you don't and i'll resend it...   I really appreciate the help, looks great for an "amateur" ....
Last edit: 10 Jan 2022 23:01 by 750 R1.
  • kzstreetfighter71
10 Jan 2022 23:33 - 10 Jan 2022 23:35
#860388
Thanks mate, yea pushed what I knew and learned a few new things in drawing this, good thing I had a day off yesterday to take my time, the bones of it is done, from here I can make adjustments easy enough, the looks of those caps you may only need the top section, the bottom can be designed into what is all ready there in the one I’ve drawn. If you get me.or are these the 2 separate pieces?
Last edit: 10 Jan 2022 23:35 by kzstreetfighter71.
  • kzstreetfighter71
10 Jan 2022 23:39
#860389
There will be plenty of room for them, those holes in the piece if drawn are 80mm diameter, i can close them up to make room for the lip and have them a snug fit.
  • 750 R1
11 Jan 2022 00:10
#860391
I just sent you an email, I screwed up on the measurements, its 220mm long by 125 wide, plenty of room for the caps to be recessed in. I've explained everything {I think}, in the email...
  • kzstreetfighter71
11 Jan 2022 00:38
#860392
All good, got your email and replied.
  • 750 R1
11 Jan 2022 00:43
#860393
Ditto....
  • Mikaw
  • Mikaw's Avatar
10 Feb 2022 12:50
#862094
Is this the look your going for…..
  • 750 R1
10 Feb 2022 15:10
#862097
Some people shouldn't be allowed anywhere near motorcycles, or tools for that matter.....
Just to clear things up....
  • Wookie58
  • Wookie58's Avatar
  • Moderator
10 Feb 2022 15:51
#862104
Looks awesome
