1978 KZ650 Bike Build 06 Dec 2021 17:55 #858704
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1859
Looks good, what paint did you go with?
1978 KZ650 Bike Build 07 Dec 2021 04:33 #858715
  • hardrockminer
  • hardrockminer's Avatar Topic Author
  • Thank you received: 1022
Tremclad Hi Heat Semi Gloss.  I need to go to a city to buy VHT.  Will use it on the brake calipers.
1978 KZ650 Bike Build 07 Dec 2021 11:15 #858737
  • Mikaw
  • Mikaw's Avatar
The Tremclad is a good match.
1978 KZ650 Bike Build 10 Dec 2021 19:27 #858934
  • hardrockminer
Running into a few hiccups.  I put all the engine mounts in place except the rear upper.  It's about a half diameter off the hole.  Not sure why...all the other ones fit easily and there is no obvious damage to the frame.
I moved onto setting the timing.  Everything went well but I need 5 shims that I don't have so I ordered parts to convert to shim over bucket.  Waiting for them to arrive.
Still waiting for a new swingarm bolt so cannot work on the back end.  That left the front end.  It all went together quite well.  The triple tree is from a Z1.  The fender was a bit rusty but otherwise OK, and it cleaned up nicely with a bit of Mothers polish.
Last edit: by hardrockminer.
1978 KZ650 Bike Build 11 Dec 2021 13:24 #858961
  • Skidmark
  • Skidmark's Avatar
  • Thank you received: 260
You may just need to rock the motor using the play in the other engine mounts to get that last bolt in.
Retired gearhead
'81 KZ-750 E2
'87 Suzuki Savage 650 Street Tracker
1978 KZ650 Bike Build 11 Dec 2021 16:10 #858964
  • hardrockminer
I tried that...kept them all loose but it didn't work.  So I drilled the hole in the mount a tad bigger.
1978 KZ650 Bike Build 01 Jan 2022 15:55 #859919
  • hardrockminer
The swingarm bolt arrived but I need a bushing.  The old one is frozen to the remaining bolt shaft.  I found one on ebay and ordered.  Should arrive in a couple of weeks.  Not much that I can do without it so I decided to check out what the bike would look like when complete.  It was a useful exercise as I discovered that my sidecovers for a B2 are not the same as a D1, which is the frame I'm working with.  I have the right one but had to order a left one.  I also discovered there is a difference in the tail piece....D1 frames are not made for one.  So it will sit in the spares box for now.
1978 KZ650 Bike Build 06 Jan 2022 07:56 #860074
  • rstnick
  • rstnick's Avatar
  • Thank you received: 374
Coming along well.
The D side covers are taller in height, they come down lower in the triangle of the frame tubes.
One peg mount on the covers is in a different location too on one or both sides.
Some have managed to fit the tail to a D model 650.
The seats are different though, to allow the tail to fit behind.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
1978 KZ650 Bike Build 19 Jan 2022 12:19 #860758
  • hardrockminer
The bushing arrived and the swingarm is now properly installed.  While waiting I began working on wiring.  The main harness had been unwrapped so I was left with a bit of spaghetti to figure out.  I have the front of the bike done but am having a bit of trouble with the other end.  Could someone show a couple of photos of how the harness attaches to the frame under the tank and near the battery box?
1978 KZ650 Bike Build 23 Jan 2022 07:38 #860917
  • rstnick
  • rstnick's Avatar
These may help:
Ed's C1:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
The following user(s) said Thank You: hardrockminer
1978 KZ650 Bike Build 23 Jan 2022 12:47 #860938
  • hardrockminer
Thanks Ron.  They were very helpful, although I have both flasher units on the left site.  (This is a D1). But he right side photo was very useful.
I've been working on wiring for a couple of days now.  The headlight, brake lights, signals and horn are all operating correctly now.
1978 KZ650 Bike Build 25 Jan 2022 13:17 #861076
  • hardrockminer
The Coquihalla highway is finally open again after last November's rain storms, so I drove down to Chilliwack to my favourite Vapour Blaster for a little engine cleaning.  It always amazes me how a thorough cleaning can make an engine look new again!  This engine won't go into the rebuild project, as I already had one ready to go.
