1977 KZ1000 Restomod 25 Jun 2023 10:33 #886394
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1885
I think if the blue was darker (like the indoor shot) it would be killer (the green is nice but there are a lot of green Kawasaki out there)
1977 KZ1000 Restomod 25 Jun 2023 10:42 #886399
  • calum
  • calum's Avatar Topic Author
  • Thank you received: 394
Thanks guys, the coin flip might be the way to way to go...
Wookie: both photos were outside with the test pieces in the sun. The darker one was taken with the sun behind me.
I'll check the blue paint again - I think the base coat was a light metallic blue and the candy was darker. If so I can probably just put a few more coats of candy on and it should be a bit darker.
1977 KZ1000 Restomod 26 Jun 2023 09:35 #886452
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
  • Thank you received: 270
I have to go blue. Green, to me, was a bad luck color. My 80s ELR was stolen
Wife's little bike... 1984 GPZ 550 Kerker and DynaJet stage I kit
Wife's BIG bike...... 1981 GPZ 1100 Kerker and factory FI Mikuni RS34s W/ K&N pods
1977 KZ1000 Restomod 26 Jun 2023 12:54 #886469
  • Stereordinary
  • Stereordinary's Avatar
  • Thank you received: 134
I agree that if the blue was darker it would be the way to go. But how about mixing the two and getting a turquoise?
A breeze from the west.
‘90 ZR550 Zephyr (x2)
1977 KZ1000 Restomod 26 Jun 2023 15:02 #886472
  • Move0ver
  • Move0ver's Avatar
  • Thank you received: 56
look at "Moro Blue" its an Audi color and the color I went with on my Z1.  If you add some metal flake/metallic to it, it might be exactly what you're looking for.
1977 KZ1000 Restomod 26 Jun 2023 15:31 #886473
  • Skidmark
  • Skidmark's Avatar
  • Thank you received: 260
Since I cannot decide which color looks best, I think that you should decide!
Retired gearhead
'81 KZ-750 E2
'87 Suzuki Savage 650 Street Tracker
1977 KZ1000 Restomod 28 Jun 2023 08:29 #886568
  • calum
Thanks guys. I was originally tending towards the green, but I think I'l go with the blue and add a few more coats of the candy to make it a little bit darker.
The following user(s) said Thank You: Skidmark, Stereordinary, Wookie58
Last edit: by calum.
1977 KZ1000 Restomod 28 Jun 2023 08:47 #886570
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1983
Darker Blue Please
1977 KZ1000 Restomod 28 Jun 2023 09:16 #886572
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
  • Thank you received: 223
The ZRX1200 had a beautiful dark blue. 2004 I think.
1977 KZ1000 Restomod 01 Jul 2023 11:32 #886698
  • calum
Did some bead blasting today. Will do the forks and tank next week and then start painting (should have the frame back by then).
The following user(s) said Thank You: Scirocco, Wookie58
1977 KZ1000 Restomod 02 Jul 2023 08:52 #886737
  • calum
Finally got around to pulling the forks apart today. Will bead blast the lowers next week but before I do I was wondering if it's possible to remove the compression daping screw. I don't think it will come out without drilling out the plug on the side but I figured I'd ask just in case anyone knows better...
Also, I'd be interested to know what the screw actually does - how does it actually restrict oil flow?
1977 KZ1000 Restomod 02 Jul 2023 09:10 #886742
  • Wookie58
  • Wookie58's Avatar
  • Moderator
The screw changes the size of the by-pass passage (like a mixture screw on a carb) to adjust the oil flow rate
