1977 KZ1000 Restomod 08 Apr 2023 10:44 #882704
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1994
I vote for the new option mounted below the tail light.
As mentioned , I am glad our plates are small here in the USA
1977 KZ1000 Restomod 08 Apr 2023 11:13 #882709
  • Kelly E
  • Kelly E's Avatar
  • Online
  • Never Give Up. Never Surrender
  • Thank you received: 318
You need to get together with all your fellow bikers and petition the government for a license plate that's not the size of a barn door. Those are a ridiculous size for a motorcycle.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
And more
1977 KZ1000 Restomod 08 Apr 2023 11:44 #882712
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
  • Thank you received: 223
I like the plate up under the seat more than below. It’s not subtle but it’s simpler. Simpler is better.
And that plate makes one heck of a splash guard.
1977 KZ1000 Restomod 08 Apr 2023 12:42 #882714
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1916
Definitely better up there, that must be worth 10mph when it's removed
1977 KZ1000 Restomod 09 Apr 2023 15:12 #882812
  • calum
  • calum's Avatar Topic Author
  • Thank you received: 394
Thanks guys. I'm not sure we'd get very far with a petition ;)
I'm on the road for a bit. Will make a second bracket for the top when I get back - the bracket is one of the few things I can chop and change without getting approval, so I can have two ready to go and decide later.
Will make the new one out of two bits of 8mm bar to try and hide it as much as possible.
1977 KZ1000 Restomod 12 May 2023 12:17 #884553
  • calum
Finally got the countershaft sprocket and rear wheel aligned properly and then stripped the frame. I just need to redo the brackets for the tail section so it actually lines up with the tank and seat. After that it's time to start painting.
I got a chain guard from a local guy but it needed a bit of work, it was made for the stock shock angle. The guy I got it from did the welding - I would have definitely made a mess of it. Also made a guard for the brake line out of some PVC. It is just there to stop the braided line eating into the paint on the swingarm.
1977 KZ1000 Restomod 12 May 2023 12:36 #884554
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Coming together nicely, it's all the little bits that eat the time. I can't believe I'll be a year in at the end of this month. I had hoped to be a lot further along
1977 KZ1000 Restomod 12 May 2023 12:55 #884558
  • calum
I'm 2 1/2 years in so I reckon you're doing OK ;)
The following user(s) said Thank You: Nessism, Wookie58
1977 KZ1000 Restomod 13 May 2023 14:52 #884612
  • Buzz Nichols
  • Buzz Nichols's Avatar
  • Thank you received: 105
Beautifully tidy work, Calum
1978 KZ1000 LTD
1977 KZ1000 Restomod 25 Jun 2023 07:22 #886381
  • calum
Got some test pieces for the paintwork done today. The yellow matches the shocks and the green is the '76 A4 green. I didn't do the candy layer properly (not enough time between coats) as it was just to test the colours, but it still turned out OK.
These are the best photos I managed to take. What do you guys reckon, green or blue?
1977 KZ1000 Restomod 25 Jun 2023 09:35 #886389
  • Move0ver
  • Move0ver's Avatar
  • Thank you received: 56
tough call... they both look really good.
Heads: Green
Tails: Blue
flip the coin and (while it's in the air) if you hope it lands on a particular side, pick that color.
I think if the green were a little darker/more olive, I'd say go with that.
1977 KZ1000 Restomod 25 Jun 2023 09:45 #886391
  • Stereordinary
  • Stereordinary's Avatar
  • Thank you received: 134
I like the green, personally. The blue is very nice also, but sort of plain to me.
A breeze from the west.
‘90 ZR550 Zephyr (x2)
