The rusty hulk 06 Jun 2020 13:54 #827467
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1859
Your a frickin animal, the speed you did that is amazing. Nice job.
The rusty hulk 06 Jun 2020 17:09 #827483
  • calum
  • calum's Avatar
  • Thank you received: 390
I agree, not even a month later and ready to ride. Nice work.
The rusty hulk 06 Jun 2020 18:10 #827498
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1022
Looks a lot better than when you first bought it!!
The rusty hulk 06 Jun 2020 18:47 #827500
  • ckahleer
  • ckahleer's Avatar
  • Thank you received: 133
Do you sleep?
94 KE100
81 CM200t
82 KZ305
79 KZ400
85 VT 500c
85 VF1100c
The rusty hulk 06 Jun 2020 19:14 #827503
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1972
If you have the time and / or are retired . Anything is possible.
Lets all stand by for his next project
The rusty hulk 07 Jun 2020 05:38 #827509
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 601
Well done, and done quick!
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
The rusty hulk 07 Jun 2020 05:50 #827510
  • Thank you received: 2829
The rusty hulk 07 Jun 2020 06:10 #827513
  • JR
  • JR's Avatar
  • Thank you received: 429
the ugly duckling became a swan !
Beautiful bike
The following user(s) said Thank You: Barry1
The rusty hulk 18 Jun 2020 10:53 #828384
  • 73z1
  • 73z1's Avatar Topic Author
  • Thank you received: 103
I can see the air screw from the back side of 73 carbs (no brass jet blocking view)
I cannot see the air screw from the back side of 75 carbs, there is a brass jet blocking the view.
Is this normal ?
#1 plug is black with 73 carbs (cleaned twice and replaced plunger).
The rusty hulk 18 Jun 2020 11:40 #828388
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1899
Do you have any pics? I am a little confused about your description :unsure: :unsure: :unsure:
Last edit: by Scirocco.
The rusty hulk 19 Jun 2020 05:53 #828446
  • slmjim+Z1BEBE
There is a brass idle air jet at the mouth of the venturi on the later VM28's circa late '74Z1 and all '75 Z1, the ones with the small drain screw. The brass jet is just upstream of the idle mix screw. The orifice of the brass jet is fairly large, guessing .035 or so if calibrated eyeball isn't failing. Should be able to see a tiny portion of the tapered end of the idle mix screw using good light & maybe some magnification.
The earlier earlier VM28's circa '72 through late '74 Z1, the ones with the large drain plug, have no brass idle air jet.
Note that Mama Kaw/Mikuni changed the taper of the idle air screw concurrent with the myriad of other changes made to the late-74/all '75 VM28's.
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: by slmjim+Z1BEBE. Reason: Typo
The rusty hulk 19 Jun 2020 09:57 #828462
  • 73z1
This is a 73 carb, you can see the air screw.
