Saving a '81 KZ750-E 08 Jan 2021 17:44 #841394
  • Skidmark
  • Skidmark's Avatar Topic Author
  • Thank you received: 260
I managed to clear enough space to get to my cylinder head bench. Since the valve clearance will decrease as the valves wear into their new seats, I assume it would be better to be at the large end of the recommended clearance of .08 - 1.8 mm.
Retired gearhead
'81 KZ-750 E2
'87 Suzuki Savage 650 Street Tracker
Saving a '81 KZ750-E 08 Jan 2021 18:11 #841395
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1906
I think you recommended valve clearance of 0.08 - 0.18 mm :whistle: :whistle: :whistle:
Saving a '81 KZ750-E 08 Jan 2021 18:25 #841396
  • Skidmark
I am saying it would be preferred to be closer to 1.8 mm than .08 mm for a rebuilt head/fresh valve job.
Retired gearhead
'81 KZ-750 E2
Saving a '81 KZ750-E 08 Jan 2021 18:37 #841397
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2681
I'd target the higher end of the range.
Saving a '81 KZ750-E 09 Jan 2021 01:00 #841413
  • Mc Tavish
  • Mc Tavish's Avatar
  • Thank you received: 35
Scirocco wrote: I think you recommended valve clearance of 0.08 - 0.18 mm :whistle: :whistle: :whistle:
I think Scirocco is saying dont confuse 0.18mm with 1.8mm.
1978 z650C
Saving a '81 KZ750-E 09 Jan 2021 07:58 #841424
  • Skidmark
I didn't notice I missed a decimal place... :S
Retired gearhead
'81 KZ-750 E2
Saving a '81 KZ750-E 09 Jan 2021 11:59 #841439
  • Skidmark
I have the following valve clearance measurements:
Exhaust: 1) .18 2) .18 3) .15 4) .18
Intake: 1) .20 2) .18 3) .20 4) .18
#1 and #3 intake are one shim increment over the recommended valve clearance. Looks like I need two more shims, or I run with it knowing the clearance will come into range as the seats wear in. Only .02 mm above the top of the range.
Retired gearhead
'81 KZ-750 E2
Saving a '81 KZ750-E 09 Jan 2021 14:10 #841443
  • JR
  • JR's Avatar
  • Thank you received: 435
the last time I need shims my local small Kawasaki dealer had them for me in a couple or 3 days. A two pack which didn't cost much. I tend to err on the side of caution.
Your bike is going to be awesome.
Last edit: by JR.
Saving a '81 KZ750-E 09 Jan 2021 15:03 #841447
  • Skidmark
I went ahead and ordered the two addition shims I need. Thanks.
Retired gearhead
'81 KZ-750 E2
Saving a '81 KZ750-E 10 Jan 2021 18:09 #841504
  • Skidmark
calum wrote: Loads of space!
I imagine you can hardly see the change to the swingarm from the side. Nice work.
It seems to blend better than I expected, for being asymetrical and all.
Retired gearhead
'81 KZ-750 E2
Saving a '81 KZ750-E 12 Jan 2021 17:08 #841607
  • Skidmark
Tinkered on the bike for a while today, but it all seems to be "invisible" work. No real changes in appearance. I cut my chain to length, and riveted the master link on. Adjusted the chain tension and torqued the rear axle. Finished with all of the engine mount bolts - a couple had to be hand ground since the same size bolts I could only find with bigger hex heads. All of the motor mounts are torqued now. Filled and bled the rear brakes, and torqued the counter shaft sprocket nut. Sometimes you can tinker for hours and step back and say you got a lot done, but none of it shows!
Retired gearhead
'81 KZ-750 E2
Saving a '81 KZ750-E 12 Jan 2021 18:26 #841610
  • krazee1
  • krazee1's Avatar
  • Thank you received: 197
Skidmark wrote: I have the following valve clearance measurements:
Sorry I wasn't around to reply sooner, if it was me I would run it with the measurements/shims you have installed and check it in 500 miles or so. A little loose isn't going to cause you any problems, I don't think that is even over spec. enough to cause any noise. I do have another $.85 for postage if you feel that you need a couple more shims.
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
