Saving a '81 KZ750-E 08 Aug 2020 14:38 #832426
  • Skidmark
  • Skidmark's Avatar Topic Author
  • Thank you received: 260
A bit more cleaning and I can start the masking on all the mating surfaces.
The block and head hve been at this point for quite a while, now.
Retired gearhead
'81 KZ-750 E2
'87 Suzuki Savage 650 Street Tracker
Saving a '81 KZ750-E 09 Aug 2020 14:44 #832505
  • Skidmark
Retired gearhead
'81 KZ-750 E2
Saving a '81 KZ750-E 09 Aug 2020 15:21 #832508
  • Skidmark
Retired gearhead
'81 KZ-750 E2
Saving a '81 KZ750-E 10 Aug 2020 14:34 #832575
  • Skidmark
The top end is almost sealed. All of the side/case covers require cleaning before they get put on. Still need to cap off the valve cover vents, intake/exhaust ports.
Retired gearhead
'81 KZ-750 E2
Last edit: by Skidmark.
Saving a '81 KZ750-E 10 Aug 2020 14:54 #832584
  • Skidmark
I am using all of the old hardware and studs at this point. Final assembly will with APE studs and stainless case screws. ;)
Retired gearhead
'81 KZ-750 E2
Saving a '81 KZ750-E 10 Aug 2020 16:18 #832601
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2679
Looking good!
What are you going to paint with? I used VHT and regret it. Wish I knew what kind of paint Kawasaki used. That stuff was tough!
Saving a '81 KZ750-E 10 Aug 2020 16:30 #832604
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1863
Nessism wrote: Looking good!
Agree, KHI paint shrugged off the Paint stripper didn’t it.
Saving a '81 KZ750-E 10 Aug 2020 16:35 #832606
  • Skidmark
I am going to use PJ1 engine and case paint (rattle can). I have not found a heat resistant semigloss clear yet. They have the good stuff in the EU, but they are not allowed to ship it to the US. Since I plan on exposing the aluminum (fins, text, cam cover ends) I wanted to put a couple coats of clear on it.
Retired gearhead
'81 KZ-750 E2
Saving a '81 KZ750-E 10 Aug 2020 17:20 #832616
  • Mikaw
  • Mikaw's Avatar
Saving a '81 KZ750-E 11 Aug 2020 17:19 #832677
  • Skidmark
Cleaning all the gasket surfaces is getting very time consuming. The final assembly will go quicker than this, I bet! Slowly getting closer to trying to lift this thing into my blast cabinet. I hope I have enough room to move the gun around with it in there...
Retired gearhead
'81 KZ-750 E2
Saving a '81 KZ750-E 11 Aug 2020 18:17 #832680
  • Mikaw
  • Mikaw's Avatar
Go buy an old lazy Susan from Salvation Army so you can spin it in your cabinet
Saving a '81 KZ750-E 11 Aug 2020 18:35 #832681
  • Skidmark
You can see the blast cabinet against the wall. I think it will be too tight a fit to spin around in there! Good idea, though. I will need to put it in and take it out for repositioning several times. It's not the biggest cabinet, for sure.
Retired gearhead
'81 KZ-750 E2
