Saving a '81 KZ750-E 19 Apr 2020 11:02 #823672
  • Skidmark
  • Skidmark's Avatar Topic Author
  • Thank you received: 260
I will be looking in my filler neck. Enough said. I have a target of late summer, early fall for the first test ride. When I count the time to ship the POR15 products here, I have been after this tank for 5 weeks now. The time to get things right never ends up what you think, but the end results are worth it.
Retired gearhead
'81 KZ-750 E2
'87 Suzuki Savage 650 Street Tracker
Saving a '81 KZ750-E 20 Apr 2020 13:16 #823750
  • Skidmark
24 hours into this soak, so I turned the tank nose up (was vertical, nose down). I couldn't resist peeking inside to see how it's going. At 3 gallons I figured the fluid line is still below the fill neck. It looks like this stuff is doing the trick!
Retired gearhead
'81 KZ-750 E2
The following user(s) said Thank You: Scirocco
Saving a '81 KZ750-E 20 Apr 2020 13:19 #823752
  • Skidmark
As I pulled the filler neck plug, the tank started out-gassing. I slowly bled off the pressure making sure not to breath. I didn't expect this stuff to produce any gaseous pressure. Interesting...
Retired gearhead
'81 KZ-750 E2
Saving a '81 KZ750-E 20 Apr 2020 14:59 #823757
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1929
The inside of the tank looks really clean and rust free, you did very good job Skidmark!!! Now it´s time for the final coating.
May i ask. what brand of phosphoric acid did you use?
Saving a '81 KZ750-E 20 Apr 2020 15:02 #823758
  • Skidmark
Nessism posted this link earlier in my thread:
www.homedepot.com/p/Klean-Strip-1-gal-Co...-GKPA30220/100406369
Retired gearhead
'81 KZ-750 E2
Saving a '81 KZ750-E 20 Apr 2020 15:18 #823759
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
Why ever i get an Access Denied, Looks like European IP´s get blocked on some US market place.
Access Denied
You don't have permission to access "www.homedepot.com/p/Klean-Strip-1-gal-Co...-GKPA30220/100406369" on this server.
Reference #18.2d651002.1587420897.14cbe564
Last edit: by Scirocco.
Saving a '81 KZ750-E 20 Apr 2020 16:02 #823764
  • Skidmark
Retired gearhead
'81 KZ-750 E2
Saving a '81 KZ750-E 20 Apr 2020 19:41 #823777
  • Skidmark
Final mustered the motivation to get the heart on the surgery table.
Retired gearhead
'81 KZ-750 E2
Saving a '81 KZ750-E 20 Apr 2020 20:39 #823786
  • Skidmark
Kudos need to be given, once again, to Nessism. His advice through this process so far has been a tremendous help. I tried my own way to clean this tank, and his earlier suggestion turned out to be the one that worked the best. This forum rocks!!
Retired gearhead
'81 KZ-750 E2
Saving a '81 KZ750-E 20 Apr 2020 21:32 #823788
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1885
+1 on “This forum rocks”
Saving a '81 KZ750-E 21 Apr 2020 01:37 #823799
  • gordone
  • gordone's Avatar
  • Thank you received: 67
I don’t know its cheaper but I have bought 75% concentration and just reduce it with water.
petit-agentur.no/products/fosforsyre-75fg-1-liter
Project:
Saving a '81 KZ750-E 21 Apr 2020 02:39 #823802
  • 750 R1
  • 750 R1's Avatar
  • Thank you received: 394
There's a cheap way to buy Phosphoric acid, all milk companies use about 60% concentration to clean the stainless equipment at the bottling plant {or what ever you call it}, I bought 20 liters of it at 60% and watered it down to 20% , giving me 60 litres of rust converting phosphoric acid, most rust converters that use it are between 12 and 20 percent. Most chemical stores here in Australia stock it for milk scum removal, should be similar over seas.... I didn't need it all for motorcycle tanks either, I use it for car restoration as well, my son and I have 3 older cars we are restoring....{just in case you were wondering}....;)
Last edit: by 750 R1.
