Retroactive KZ750E Project Thread 02 Nov 2019 05:55 #813427
  • calum
  • calum's Avatar
  • Thank you received: 393
Hey Ed,
I probably didn't word that so well. I have a good 2k clear, it was more of a question of whether it was better to just leave the polished bits as they were (upkeep vs. yellowing etc.). I ended up doing a clear coat this morning, now I don't have to worry about the paint peeling of at the edges (was mostly concerned about the clutch cover). The AC and timing covers weren't polished as well as the clutch cover (was sick of polishing) but the clear coat made the sanding marks less obvious.
Won't help you much, but I get all my paint from these guys: www.motorradlack.de
The clear coat for engines shouldn't go yellow for temps under 160 °C (will be interesting to see how the cooling fins on the head hold up over time) and it's supposed to stick to polished aluminium - I guess we'll see. I do trust those guys, they specialise in bikes and given that after all the shit I've dropped on my frame there still isn't a mark on it, I think I should be fine :)
Must be about time to start a project thread...
Retroactive KZ750E Project Thread 18 Jan 2020 14:41 #817372
  • gandris77
  • gandris77's Avatar
  • Thank you received: 0
Hi!
I read the KZ 750 project.
It is very versatile and I learn a lot from it.
I wasn't careful, I can't find where you bought the sticker set ... (blue-black on the tank, fenders)
Last edit: by gandris77.
Retroactive KZ750E Project Thread 17 Feb 2020 17:23 #819510
  • Nessism
  • Nessism's Avatar Topic Author
  • Thank you received: 2681
gandris77 wrote: Hi!
3M pinstripe tape was used. Laid down the stripes by hand. 3M makes good shit and I purchased direct from them to assure a fresh batch. My application could have been a little better, particularly on the side covers, but they turned out good enough.
Retroactive KZ750E Project Thread 27 May 2020 12:13 #826668
  • motorcycle2020
  • motorcycle2020's Avatar
  • Thank you received: 1
Just found your restoration. What an outstanding job.
Retroactive KZ750E Project Thread 28 May 2020 17:06 #826781
  • 750 R1
  • 750 R1's Avatar
  • Thank you received: 394
Nessism wrote:
Dr. Gamma wrote: I love what you did with your KZ750E. I followed your build for a long time. Congrats on making BOTM!!!! I built a KZ750E back in the early 80's. I used many of the same parts you did. The GPz feetpegs, and the oil cooler were the same exact parts that I used on my E model. Your build brought back more than a few memories.
I road raced mine in a few WERA endurance races back then. I parked it when the Honda Interceptor came out in '83. After that it became my primary streetbike. Gold wheels were my trademark back then as you can see in the one photo.
Gold wheels eh? Seems fitting for the era. :laugh:
Hi ED, do you by any chance remember what the gold paint you used to paint your wheels was ?, I've been looking for gold wheel paint myself and some of it is just far to bling for my liking.
Retroactive KZ750E Project Thread 28 May 2020 17:32 #826784
  • Nessism
Dr. Gamma is the guy with gold wheels, not me. You might want to PM him for info.
Last edit: by Nessism.
Retroactive KZ750E Project Thread 28 May 2020 18:33 #826785
  • Dr. Gamma
  • Dr. Gamma's Avatar
  • Thank you received: 664
I sprayed the rims on my Kz750E with a now long gone Kal Gard product called KG9600 coating. The californian EPA killed this product from being sold anymore. The color was called Light Gold. #KG-9646-2.
This was before powder coat. I clean all my coated rims with a rag with carb cleaner sprayed on it. This stuff is as durable as today's powdercoats!!!!
1986 RG500G 2 stroke terror.
Retroactive KZ750E Project Thread 28 May 2020 18:52 #826787
  • Thank you received: 2829
Maybe contact Kal-Gard to see if they have something similar. They have quite a few coatings. Ed
www.kal-gard.co.za/coatings/index.html
The following user(s) said Thank You: 750 R1
Last edit: by 650ed.
Retroactive KZ750E Project Thread 28 May 2020 20:31 #826792
  • 750 R1
  • 750 R1's Avatar
Sorry ED, I should read a bit more carefully..!!
Retroactive KZ750E Project Thread 28 May 2020 20:32 #826793
  • Nessism
That Kg 9600 seems similar to gun kote.
Retroactive KZ750E Project Thread 28 May 2020 21:12 #826795
  • 750 R1
  • 750 R1's Avatar
Yes, I remember seeing a gun kote color that I liked, I think it was a ceramic finish {cerakote}.
Retroactive KZ750E Project Thread 29 May 2020 04:52 #826812
  • Nessism
I used gunkote on the wheels and brake calipers for this bike. I think gunkote requires virgin metal for application so plan on blasting your parts fully before application or it may not stick properly. And also plan on baking. Gunkote doesn't cure without heat.
