82 kz1000 ground up build
- rivman15
Re: 82 kz1000 ground up build
20 Jun 2024 13:52
I really like your choice of color. I think the brown seat would look awesome.
The following user(s) said Thank You: jowek70
- jowek70
21 Jun 2024 04:25
My welder thought the same thing but i dont think it would add anything since the cylinder head acts as the tube in that location already; the welded mounts bolt solid to the engine head and those are intended to be a stress member of the frame in the original bike. I think a smaller diameter solid shaft in the OEM location should suffice. Might be worth modeling up and seeing how it bends at work in my modeling software.
21 Jun 2024 04:44Sounds like a plan (I tend to be over cautious with these things, the only thing I would say is the donor chassis being much newer is probably significantly stiffer so probably subjects the head casting to less "twisting forces")My welder thought the same thing but i dont think it would add anything since the cylinder head acts as the tube in that location already; the welded mounts bolt solid to the engine head and those are intended to be a stress member of the frame in the original bike. I think a smaller diameter solid shaft in the OEM location should suffice. Might be worth modeling up and seeing how it bends at work in my modeling software.
Bike looks great (poss a future BOTM)
- jowek70
21 Jun 2024 07:43
no worries, appreciate the input!
and thanks for the compliments will do once she's ready.
- jowek70
02 Jul 2024 19:05
No pics sorry but have the pod filters installed on the TB’s and TB cables are on.
going to have to modify the frame a bit to clear the chain though, even with a 520 chain and sprockets and an offset front sprocket (17mm) it still rubs.
interesting that this exact setup, with stock engine, worked without issue when I did this on my dads 77 kz1000.
- jowek70
01 Nov 2024 08:46
Been awhile since last update; in the coming weeks i'll be getting the fueling system together, modifying the frame, finishing up the electronics and getting my dyno appointment set up.
Planning on spring time completion, sometime in february 2025.
- jowek70
18 Dec 2024 08:40
Man this fuel system is killing me, might try to retrofit the OEM 03-06 z1000 pump or my other idea is to run a return line from the inline fuel pressure regulator before the fuel rail.
- Saablord
06 Jan 2025 20:56
What's the trouble with your FPR/fuel system?
Gorgeous bike, by the way!
- jowek70
19 Feb 2025 07:02What's the trouble with your FPR/fuel system?
Thanks for the compliments, i appreciate it!
I ended up going with an auxilliary FPR since i'm running an in line fuel pump, just need to lay everything out now.
- jowek70
19 Feb 2025 07:02
I decided to go with a black seat since i could not get the brown i wanted from the supplier.
The following user(s) said Thank You: Mr. E
- jowek70
22 Apr 2025 04:37
Finally able to get back into this project, began cutting up the frame to clear the chainline. Going to have plates welded back in to get the frame strength back. Working with a local guy on a custom fuel rail to finalize the fuel system. Ordered clutch and throttle cables from Venhill USA. I think i'm going with a Koso gauge, its a nice TFT and should fit the bike well. Small list of parts to get ordered then a few things to fine tune and off to the dyno; spoke with the tuner last week and he seems excited to work on such a project haha. Should have more updates in the coming weeks. If all goes well and i can stay with it this time, i'm hoping to get this wrapped up by June.
- jowek70
