CSR1000 Project Build 18 Aug 2016 17:13 #739172
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2689
I was thinking that too. Unless it will be outside all the time, it shouldn't be a problem. :unsure:
CSR1000 Project Build 28 Aug 2016 10:35 #740258
  • davido
  • davido's Avatar Topic Author
  • Thank you received: 286
Ok. I couldnt live with the idea of a non waterproof tank cap. (Here in Holland its known to rain now and then). I sent the cap back and ordered a non vented model with a seperate vent valve which screws into one of the mounting bolt holes. I can run a hose from that to somewhere up by the front end.That should give me waterproofed venting.
I made a list yesterday of the things left to do.Its not a big list but theres enough on it to know that im not going to be on the road before the end of the summer. Fair enough.
It gave me a bit of a kick up the arse though ,so I spent today in the workshop. I had planned to make a new bat-box out of alu plate,but after a couple of failed attempts last week,I decided to stick with the original box and just modify it.This saves a lot of messing around.I had to fiddle a bit with the undertray to get the box to fit,so thats done and off the list.I bought a new 'blade' type fuse box,which I want to fit,so I still need to wire that in.
Thats about it for now.Nothing very exciting so no photos.
Nothing to see here.Move along now.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CSR1000 Project Build 28 Aug 2016 11:12 #740263
  • seanof30306
  • seanof30306's Avatar
davido wrote: Ok. I couldnt live with the idea of a non waterproof tank cap. (Here in Holland its known to rain now and then). I sent the cap back and ordered a non vented model with a seperate vent valve which screws into one of the mounting bolt holes. I can run a hose from that to somewhere up by the front end.That should give me waterproofed venting.
Can't wait to see install pics of that cap.
Where did you get it?
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
CSR1000 Project Build 28 Aug 2016 13:19 #740277
  • davido
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CSR1000 Project Build 28 Aug 2016 13:25 #740278
  • seanof30306
davido wrote: www.newton-equipment.com/aero-600-filler-cap-model-A68sl.html
Thanks, that is really cool.
I don't see a price anywhere. What did it run you?
I'm really looking forward to seeing pics of your install
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
CSR1000 Project Build 28 Aug 2016 23:20 #740342
  • davido
The original 'vented' model I bought was GBP105. (with VAT and postage) I sent that back and ordered the unvented modelwith the valve but they just charged me the same to make things easier. Ill post some pictures when I get it.(This one willl be in silver as they didnt have any black models).
Im also looking forward to seeing photos of it installed.Itll mean some real progress and another thing off the list!!
If youre interested in anything from the site,just give them a ring or email,I dont think the vented model is even on the website.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Last edit: by davido.
CSR1000 Project Build 05 Sep 2016 11:26 #741201
  • davido
Here we go. The seat cover . Finished and fitted!!
Built by the fair hands of a Catalan Princess. ( except the front panel,which she couldnt figure out,so, I took it to a local seat covererer and he finished it off)
Not too shabby for a first attempt eh?
And one more step forward.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
The following user(s) said Thank You: Mcren
CSR1000 Project Build 05 Sep 2016 11:30 #741204
  • Wiers
  • Wiers's Avatar
  • Thank you received: 21
Looks good and comfortable.
Getting there.
Eric
The following user(s) said Thank You: davido
CSR1000 Project Build 05 Sep 2016 12:42 #741212
  • davido
Tis comfy indeed and it also makes the position of the rearsets feel a bit more normal. Blind luck on that one to be honest!!
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CSR1000 Project Build 07 Sep 2016 06:59 #741385
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
that turned out nice!
CSR1000 Project Build 07 Sep 2016 11:06 #741430
  • davido
Yup,Im glad its done. Next thing is the flush fitting fuel cap. In the post. Waiting waiting. Still got to finalize the electrics,then once the fuel cap is sorted , I can jump into the painting. Tailpiece and f/mudguard are already in primer,though I still havent decided on colours yet.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CSR1000 Project Build 08 Sep 2016 06:22 #741516
  • 531blackbanshee
  • Vendor
who is welding your cap in?
