- Thank you received: 681
Better Than Nothing---The rebirth of a Superbike.
- Dr. Gamma
It took me about two years to dial in my chassis back in 80's. My notebooks with my notes on setup were stolen back in the mid 80's. So its going to be trial and error on setup. I was running KZ650 triple trees with Kayaba fork legs with a modified frame with a different fork angle. I would kill to have my notebooks back. Everything I changed, no matter how tiny it was, I wrote it down.
Its going to take me about a year just to piece my bike back together. Its going to be some time before it hits the track again. I am hurting for extra cash to spend on my toys right now too. Got to get me one of those cushy government jobs that pays you just to sit there and do nothing!!!
1986 RG500G 2 stroke terror.
- AHRMA120
- Thank you received: 2
- AHRMA120
- CruisingRam
- Thank you received: 15
Dr. Gamma wrote: I watched a old Morris mag come apart at The Springfield Mile about 10 years ago or so. Sent that rider into the fence pretty hard. Thats why I wanted to X Ray the wheels. It can't cost that much to have them X Rayed. 30 or 40 bucks a wheel??
I am not sure where you live, but if you post the city and place you live, I bet I can find you a place to x-ray or non-destructive test your wheels. I went to school to be a welding inspector and got my NRC license, and still have a list of various businesses that do industrial radiography.
Just saw you are in or near Phoenix- here ya go:
TEAM INDUSTRIAL SERVICES PHOENIX
Inspection Services
2514 N. 33rd Avenue
Phoenix, Arizona 85009
UNITED STATES
Phone: 602-269-7868
Fax: 602-269-9784
Services Offered: NDE/NDT Inspection, Liquid Penetrant Inspection, Magnetic Particle Inspection, Radiographic Testing, Ultrasonic Testing, Remote Visual Inspection, Electromagnetic Testing, Ground Penetrating RADAR (GPR), Materials Testing/Evaluation, Heat Treating, Electrical Resistance Heat Treating, Combustion Heat Treating, Induction Heat Treating, Tank Inspection and Repair, Mechanical Integrity
1975 Z1 B 900- soon to be heavily modded
Pahoa, Hawaii is my new hom
I am working hard to save up the shipping money to get my shop opened here in Hawaii
I hate electrical stuff.
- Hollywoodmx
- Thank you received: 16
Dr. Gamma wrote:
Hollywoodmx wrote: I don't want to sound like a jerk but what money would your really need to put this back together if you have all the parts?
Tires would be the most expensive, chain, various seals, fluids?
Well I wish it was that easy..
Got to put a motor together. That means the head I plan on using needs 8 fresh valves, and a good valve job. Just to be safe, I will put in new camchain, replace the valve springs. My old Yosh pistons need new rings. I would not mind finding a new set of 1015cc Slipper pistons it I could!!! Then hope the block is in spec, and no egg or taper. I NEVER put a fresh head together with used cam bearings either. Gaskits.
Now the chassis needs the S1 rearsets to be finished up. I hope they clear my tuck up Bassani pipe. If not I will have to build another style of rearsets then. I was putting Suzuki handlebar switches on both sides on bike when I parked it. I would like to get a set of Ohlins rear shocks if I could. Now if my Morris mags fail Xray test, I need like 2 grand in new wheels then!! And it goes on and on. In my book there is no skimping on the old family recipe in my book!!
Ahh, gotcha. Ya quite of bit of spending there for sure.
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- mtbspeedfreak
- Thank you received: 36
If you didn't want to spring for mag wheels right away, you could find a set of Z1R 18" wheels for significantly less than the cost of mags.
2000 ZRX 1100
1976 KZ 900- Daily Driver
- Dr. Gamma
Found my 73mm Moriwaki two ring piston set and barrel. Might use these over my 70mm Yoshimura slipper pistons because the Moriwaki pistons have a bit less dome height. Got to cc the two good heads I have to give me an idea on what I have for compression ratio. Too bad someone stole all my notebooks years ago. I kinda remember about 220 or 230 pounds of compression after about 10 kicks or so. Never had anything but a kickstarter on my KZ1000.
I have three sets of cams. They are marked, Big, Bigger, and Biggest!!! The box marked Big are what I think are Yoshimura Bonneville cams. The Bigger set are Moriwaki with the words "Super Bonneville" in dry marker on the boxes. The ones marked Biggest I know are Norris 440SC's with .437 lift, and 284 duration marked on the box. I started using Moriwaki Engineering parts after Yoshimura started racing Suzuki GS1000's. The quality of Yoshimura's Kawasaki parts went way down hill after about 1980 or so. I got a set of cams from Yosh, and I had FOUR DIFFERENT lift measurements on just the intake cam!!! I'm talking over .040ths difference in four lobes. Thats when I found Moriwaki Engineering cam and pistons from Champion Kawasaki in California. They were exactly like what Yoshimura made but of a higher quality. Just like Yoshimura made before they went over to Suzuki. I believe Mr. Moriwaki was Pops Yoshimura's son in law.
So What I really need from someone is the lift and duration specs on the Yoshimura "Bonneville Special" cams. and the Yoshimura or Moriwaki Eng. "Super Bonneville" cams.
I think the 440SC's are a tad too much for the street!! I got to find out what I have in the other two camshafts to see what ones I will start out with. At the rate I am going I might have a running bike in about 18 or so months from now!!!
- mopguy
- Thank you received: 168
- Dr. Gamma
I am going have to start dealing in illegal substances just to pay for the parts that I need just to put a motor together. My local Kawasaki dealership thinks they are selling diamonds not motorcycle parts. 70 bucks for a cam chain idler wheel. They are on drugs for sure!!!
- kaw-a-holic
- Thank you received: 249
Kawasaki dealer will stuck you dry. Have you visited www.z1enterprises.com/ ? You may find some NOS parts you looking for for cheaper there. I have also found NOS parts on eBay, some are cheaper there some are not. Really looking forward to your build. I may be moving to the Phoenix area myself by September 1st. If so I some really like to meet you and check out the bike in person.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- Dr. Gamma
kaw-a-holic wrote: Dr. Gamma
Hope you like the heat?? I moved down here from up near Sedona, and I can't believe how much hotter it is here in the valley. I want to move back to near Prescott,or Sedona because its alot cooler up there. Plus it gets down in the 40's up there in the winter. Flagstaff is like living in a midwest city. It gets really cold up there in the winter and it snows alot. They even have two ski resorts near Flagstaff. BIG DIFFERENCE FROM 100 DEGREES TO 115 DEGREES WHEN YOU ARE OUTSIDE!!!
September the temps are a little cooler in Phoenix by then. The winters are great. But then you have to dodge all the 90 year old snowbirds in their big old '90's vintage Grand Marquis' You can spot them by their Illinois, Indiana, or a plate from anyplace it snows hard in the winter!!
- mtbspeedfreak
Cheers man!
2000 ZRX 1100
