- Thank you received: 676
Doctorot's '78 KZ1000 build
- DoctoRot
I found a steel one at a bike swap for real cheap, but thanks for looking out.531blackbanshee wrote: wow that is some real nice work.
your bike is looking really good.
i love the way the handlebars turned out.
i think i found a triple with the right leg size.it is steel tho.
I got the replacement piston ring ring today, I'm going to attempt this again tomorrow, but I'm a little nervous about putting the top end together. Ive never done this before and everything I have read says that is crucial to do correctly, so Im going to put my piston ring end gap figures up here. Hopefully someone will notice any errors if i make some, and hopefully avoid an expensive mistake. (probably will anyway) :sick:
72mm / 25.4 = 2.83464567 inches
TOP RING
2.83464567 x .0045 = 0.0127559055
BOTTOM RING
2.83464567 x .0055 = 0.0155905512
this came in the Wiseco 1075 kit...
- Thank you received: 797
hopefully someone will chime in with some better info.
- wireman
- Thank you received: 299
Straight out of the plummen/wireman homemade tool catalog! :laugh:DoctoRot wrote: So i called wiseco and figured out that the silver ring is the top ring, black is the second ring. Went to put the second ring on and.... SNAP. so now i'm waiting for a new ring.
I did bring the bike home yesterday, the sub frame is mostly complete, still needs the shock mounts, and it needs the rest of the bracing finished up.
Some beautiful welds.
I put the new handlebars on. They're pretty bitchin. Need to clean up the triple clamp now.
I also put in some new steering head bearings. As per usual the old races where a real PITA to remove, but i got them out and new ones in. I love homemade tools.
Nice welding!
- DoctoRot
wireman wrote: Straight out of the plummen/wireman homemade tool catalog! :laugh:
Nice welding!
Yeah i saw a photo of that tool on this site and made it. I think it was either plummen's or your photo. :lol: I can't take credit for the welding. that is the handy work of Eric Waunch of High Performance Welding in Bothell, WA. he has been squeezing some time in on the bike here and there for me.
So here is my carb cleaning experience with the pinesol. I used it straight and soaked each carb for a couple days, I noticed that the pinesol in two of the buckets had turned cloudy on day three, i figured it was because they had the dirtiest carbs in them or something.I kinda forgot about them, but on my way through the garage i remembered them and dumped them out of the pine sol. They looked pretty good, but still kinda dark.
This is where I screwed up. I should have immediately rinsed the pinesol off. But i didn't, and it turned into a oily film on the carbs. :pinch: Also the two buckets that got cloudy developed white deposits on the carbs.
I tried using solvent to remove it but all it did was remove the oil and left the film. I tryed soaking it in parts solvent hoping it would dissolve, all it did was rust some springs and a couple screws. :sick:
I then found this THIS and decided to try boiling them in lemon juice, because i screwed the pooch bad this time.
I boiled them in straight lemon juice outside on my camp stove. It has a strange smell that is not that great. I used the tray in a carb-dip can for the small parts. I boiled them for 30 minutes them immediately moved them to a pot of boiling water and boiled them for 30 more minutes. I then blew compressed air through all the passages.
It cleaned them right out! I had to do the ones with the white deposits on them 3 times till i was satisfied, but they are clean as a whistle.
The process turned all the parts dark grey and flat, and the pinsole stained the irregularitys in the castings. I think it may have pitted them slightly as well, but it could be like that from the factory for all I know. the lemon juice turned all the brass parts copper in color as they oxidized. The pot metal parts faired the worst. It seems as if the lemon juice removed a layer of paint from them, they are slightly pitted, just a bit rough not too bad. is this bad?
Also the lemon juice removed the rust, I was very impressed with this.
I bought a soda blaster and soda blasted the everything, and washed it down. They have a good shine on them now.
I started reassembly but forgot to buy a couple things so they are on hold for a moment.
On a different note, Turns out the frame is bent, possibly the swing-arm as well. Took it to Wasco Frame Repair in Tacoma a couple of weeks ago, he should be finishing up with it soon.
I did get the rind gaps sorted and the rings on the pistons.
I got a little derailed after my retardation with the carbs, but it all worked out and Im pretty happy with the results. I feel revitalized on this project, and I cant wait to get the frame back and re-do all the body work including some custom side covers!
- KZJOE900
- Admin
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- DoctoRot
KZJOE900 wrote: I don't think you should have used straight up lemon juice. I used 6 parts water and 1 part lemon juice and got very good results. As for the pitting, most likely it was already there due to moisture sitting in the carbs over the years. Or maybe do to manufacturing. But the lemon juice, especially the strength you used, will etch a little and bring out any pitting that already exists. You should be fine however. One of the main jet tubes and float towers were pitted bad on one of my carbs. Was concerned about the main jet seating properly but seems to work fine. Just as long as you didn't boil any of the rubber parts you should be good to go. I used carb cleaner and compressed air after the boiling process as well. Use Patton's pilot circuit cleaning method to spray the carb cleaner for that circuit. Also, clean the choke circuit as well with carb cleaner and compressed air. Don't forget the choke circuit passage in each of the bowls as well. Might as well go the extra mile while you have them apart. Good luck.
In retrospect the lemon juice did seem too harsh, but even then it took several times to remove the film the pinsol left. In the future i will dilute it. The pitting that is there is almost not noticeable, except on the pot metal parts. I'm going to follow your advice and clean all the circuits one more time before I put them back together, just to make sure they're good.
- Thank you received: 2098
- DoctoRot
We also started on the shock mounts, unfortunately we only had enough time to get one done. eric turned a new mount, and changed the design slightly. It now has a bolt going into it. cleaned up the design a bit, I think it looks good, gotta get a cool fastener for it though. I still need to fit the two cross braces and two braces for the steering head. Hopefully I will get to that this week. feels damn good to be getting some progress done after sitting idle while it was at the straighteners
DoctoRot wrote: We also started on the shock mounts, unfortunately we only had enough time to get one done. eric turned a new mount, and changed the design slightly. It now has a bolt going into it.
an aluminum washer machined out so that an allen head is countersunk in to it would look very nice.
glad you got some progress made,keep us posted.
- rslingshot
- Banned
- Because stock SUCKS!!!!!!
- Thank you received: 19
www.kzrider.com/forum/11-projects/390747-1977-kz1000-new-life
2000 Kawasaki ZRX1100
2004 Gsx-r 750
78 kz1000 basket case
81 yamaha xs 650 basket case
- Ederer
- Thank you received: 5
1980 KZ650 Build
kzrider.com/forum/11-projects/552156-kz6...ect-first-time-build
- Renninger
