  • Page:
  • 1
78 650 B with some work done 11 Oct 2007 21:47 #175847
  • dreamsofaz1r
  • dreamsofaz1r's Avatar Topic Author
  • Thank you received: 1
Here is the blue frame to match body work 650 with the grey pinestripes with some of the upgrades done so far. It has taken a back seat to the Z1R but still doing some stuff.
78 650 B with some work done 11 Oct 2007 21:49 #175848
  • dreamsofaz1r
Nother pic
78 650 B with some work done 11 Oct 2007 21:51 #175849
  • dreamsofaz1r
The other side. I know she is dirty, that will change when the wrenching is done.
78 650 B with some work done 12 Oct 2007 10:03 #175907
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1615
Very nice! Would you happen to have a link for that tail light, if it's new, that is...
78 650 B with some work done 12 Oct 2007 10:56 #175909
  • scumbag
  • scumbag's Avatar
  • Lewd, Screwed, and Tattooed
  • Thank you received: 5
holy dropped forks batman!
sept.1976 kz650
1980 kz650
78 650 B with some work done 12 Oct 2007 14:54 #175926
  • bkay1
  • bkay1's Avatar
  • Thank you received: 0
dude do you have any bottoming out problems?
hide the beer... the cops are here
78 650 B with some work done 12 Oct 2007 15:48 #175934
  • Thank you received: 2829
"dude do you have any bottoming out problems?"
Stock front forks have a 5.5" stroke. It sure looks like things will bump the way it is lowered. Another issue is the steering geometry. Looks like it's going to be twitchy because of the change in trail. I guess it will become very clear once it's back on the road. Ed
78 650 B with some work done 12 Oct 2007 17:07 #175937
  • dreamsofaz1r
Ahhhh Ed, but there will not be issues as the forks are at the same length from wheel mount to triple tree as it was orginally. The forks are over sized so I can use clip ons on top of the triple tree and clear the gauges and not have a hateful reach. The arm postition feels alot like if it had a set of superbike bars actually, and just had the ends turned down a bit.
78 650 B with some work done 02 Nov 2007 19:09 #179379
  • dreamsofaz1r
I am not sure what the tail light is, but it is a Balkamp item. I worked for NAPA at the time I built it and I looked through on of the lighting joober books and found it. Was only like 15 bucks.
  • Page:
  • 1
