1990 KZ1000P,, NO SPARK 03 Mar 2024 16:40 #895906
  • big tom
  • big tom's Avatar Topic Author
  • Thank you received: 0
checked for ignition coil wires green and blk from the coil,, under start condition green wire falls from 12 volts to 1.6 volts,, the blk wire goes from 12 volt to flashing OL.
1990 KZ1000P,, NO SPARK 03 Mar 2024 17:00 #895908
  • big tom
yes,, readings taken from the coil side or back side of connector with every thing plugged in
1990 KZ1000P,, NO SPARK 03 Mar 2024 18:49 #895914
  • F64
  • F64's Avatar
  • 81-KZ440D2
  • Thank you received: 353
The thing that gets me is the fact that you had cylinders 1 and 2 firing in the beginning.
This means both coils were working as well as the igniter.
On cylinders 3 and 4 you could have a short anywhere from it's coil to the spark plug.
This could be an internal short in the coil or a short along the spark plug wire.
In a dark room you could use a spray bottle of water to mist along the spark plug wire to encourage arcing if there is a break in the wire while the bike is running.
You could also have valve issues on 3 and 4 that prevent breathing in those cylinders
But try starting fluid on 3 and 4 once you get 1 and 2 firing again.
That will possibly rule out ignition problems on 3 and 4 and then we can help you from there.
I would try this before buying any more parts.
81-KZ440-D2.
LIC, NY
The following user(s) said Thank You: Wookie58, big tom
Last edit: by F64. Reason: for clarity....as i even confuse myself with my writing
1990 KZ1000P,, NO SPARK 03 Mar 2024 21:12 #895917
  • big tom
i have bad feeling that there is short somewhere and possibly ruined my new igniter already,, i never thought i wood miss the old points and condenser days,, think ill start over tomorrow checking and rechecking,,,thanks for going out of your way to help,,,if anyone has any suggestions ,, im all ears
Last edit: by big tom.
1990 KZ1000P,, NO SPARK 04 Mar 2024 01:04 #895920
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1812
It is unusual to get "OL" when using a voltmeter - can you post a picture of your meter on the settings you are using
If you have one you can test the ignition pulse by connecting a "LED" between Ignition live and the green then black wires in turn. Crank the engine and the LED should pulse (multimeters can sometimes struggle to measure a pulsing voltage)
Last edit: by Wookie58.
1990 KZ1000P,, NO SPARK 04 Mar 2024 05:28 #895930
  • F64
  • F64's Avatar
  • 81-KZ440D2
Tom, this short won't destroy your igniter.
Your spark plug is basically a short to ground. It's just the short occurs in the cylinder.
A bad short occurs outside the cylinder. It's bad because the spark is not occurring where it should.
81-KZ440-D2.
LIC, NY
1990 KZ1000P,, NO SPARK 04 Mar 2024 05:33 #895931
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
Looks like we are "tag teaming" this one, good to work together again
The following user(s) said Thank You: F64, big tom
1990 KZ1000P,, NO SPARK 04 Mar 2024 06:24 #895935
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2680
I agree, if both 1 & 2 fire, that means that both coils are getting the signal to fire.  You might want to check for voltage at the coils.  If less than 10V, there may be a supply side wiring issue.
Do your coils have removable spark plug leads?  If so, you might want to replace them.  7mm copper core wire.  And check the plug caps for resistance while they are off.  They should be 5k ohms.
The following user(s) said Thank You: howardhb, big tom
1990 KZ1000P,, NO SPARK 04 Mar 2024 09:27 #895946
  • big tom
all great suggestions,, and i will follow up with all of them today,,i have read where the standard Fluke meter is to slow to read the pulsing coils and i will check it with an LED,,The ignition coils and plug wires are new  and in spec,, the pickup coils and wires are new and in spec,, the igniter is new as well,,what i have not stated is all  these replacement parts are Caltric straight from Amazon,, im still trying to believe that they work and try not to taint any help yall offer,, sorta like ford ,dodge or chevy is best,,sorry,, but if it takes a $600 igniter for this thang to run,,, i have kz1000p parts for sale,,,, sure hope this doesnt push anyone away for your help,,,,thanks again everyone
1990 KZ1000P,, NO SPARK 04 Mar 2024 10:01 #895948
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
We will get you there, "stay the course"
do you have no spark at all (plug lead resting on the outside of the engine with a plug in it) check all 4 ?
Is the igniter bolted in place (if not it will overheat quickly)
The following user(s) said Thank You: big tom
1990 KZ1000P,, NO SPARK 04 Mar 2024 11:26 #895951
  • F64
  • F64's Avatar
  • 81-KZ440D2
You could always make Lou Dudzik's igniter using a couple GM HEI modules. I've been using it as my igniter for years.
s3.amazonaws.com/gpzweb/Ignition/GPZgmHEImod.html
But again, I would reinstall the old parts if you still have them to see if you can get cylinders 1 and 2 to fire.
I'm assuming you have new spark plugs as well.
81-KZ440-D2.
LIC, NY
1990 KZ1000P,, NO SPARK 04 Mar 2024 14:54 #895958
  • big tom
i do have new plugs in route,  back when it would run on cylinders 1&2,, i cleaned all the plugs and rotated each one through to at least confirm they fire,,i know,,, im cheap,, i planned to spend the day with it but,, a doc visit,,,enough said there,,gonna be long night rechecking everything so yall can get on to help the next lost soul,, cant thank yall enough,, ill get back with you,,,,,,, yes the igniter is bolted up
