  • Page:
  • 1
  • 2
New rider and a Barn find so any advice 15 Oct 2023 00:47 #890493
  • Larry G
  • Larry G's Avatar Topic Author
  • Thank you received: 11
Hey so I am new to riding this hopefully will be my first bike and advice is needed  hopefully I  haven't wasted my money for this I do have the tank and it was stored dry but I am no mechanic .
My name is Larry I am in Germany thanks for having a Fourm hopefully some one could give me some guidance on this.
Last edit: by Larry G.
New rider and a Barn find so any advice 15 Oct 2023 06:38 #890503
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1972
Welcome Larry
 We are here to help
But where are the pictures ???
New rider and a Barn find so any advice 15 Oct 2023 06:44 #890504
  • Larry G
Sorry still learning the forum controls that's better
New rider and a Barn find so any advice 15 Oct 2023 07:14 #890506
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2678
Looks like you found yourself a nice project.  That bike was someone's baby, based on all the nice accessories installed.
You might want to check out my signature for some helpful links...
New rider and a Barn find so any advice 15 Oct 2023 07:24 #890507
  • Larry G
Yeah  I know the family it came from they are all complete petrol heads. My friends father rebuilt the engine so hopefully no mechanical issues and the wiring is stock except the led lights.
He even painted the engine block when it was rebuilt. He was a professional engineer and mechanic for volvo so he was very capable.
hopefully all i really need is cosmetic work but who knows what is going to happen.
Thanks for the encouragement I am kinda in over my head but thats how you learn.
The following user(s) said Thank You: sf4t7, howardhb, Wookie58, Kelly E
New rider and a Barn find so any advice 15 Oct 2023 09:15 #890511
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 370
Welcome to the fun!  You have found a great machine to work on.  Take you time and go through each system and make choices on what is needed ask questions, but most important is to enjoy the process.
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: Larry G
New rider and a Barn find so any advice 15 Oct 2023 09:34 #890512
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1789
Welcome from the UK Larry, best advice I can offer is "be methodical" and work through it one bit at a time. In the end you will have a great ride
New rider and a Barn find so any advice 15 Oct 2023 12:12 #890522
  • Larry G
Thanks Wookie58 is there any particular order I should start like I was thinking  carburettor first and air I don't think I have the money this year to strip the frame so my plan is to get it as stock and running as possible. I am doing my licence at the moment so money is tight buying lessons and gear in Germany is expensive. Any advice is greatly appreciated and should I move this to a project thread
New rider and a Barn find so any advice 15 Oct 2023 13:02 #890527
  • Nessism
  • Nessism's Avatar
Start by reading the "new members thing to know" thread.  Inside you will find several "must have" maintenance items that should be dealt with before trying to start the bike.
Personally, I'm a carb guy, so I go straight at those.  I have O-ring kits, if you can't find what you need in the local market.  Replace the rubber carb boots.  Adjust the valves.  Clean out the tank.  Replace fuel line.  Break down the brake calipers and master, looking for corrosion, and replacing parts as needed.  Where to start?  Everything!
Last edit: by Nessism.
New rider and a Barn find so any advice 16 Oct 2023 05:33 #890543
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 601
Nice find & project!
You indicate you're not a mechanic. By the time you get this one done, you will be...
Our preference on a project like this is - before we make it go, we make very sure it will stop. Brakes are very high-priority.
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Last edit: by Wookie58.
New rider and a Barn find so any advice 16 Oct 2023 06:01 #890544
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 377
Welcome. You have quite the project there.
Get it running then work on the safety and maintenance items (brakes, tires, chain and sprockets, lights) then ride it while you do the cosmetics.
Good luck!
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
New rider and a Barn find so any advice 16 Oct 2023 06:22 #890545
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Moving to a "project" thread would be a great way for us to keep track of what you are doing and the progress you make. As far as "what order" there are several viewpoints already expressed on this, my personal opinion is that as long as you have gone through all the main systems prior to taking it on the road, the order should be determined by your budget and confidence levels (some things like cleaning and greasing head bearings etc is cheap, other things like brakes maybe not so cheap depending on what is required)
  • Page:
  • 1
  • 2
