Speedo/Tacho damper fluid
  • zedsledfred
  • zedsledfred's Avatar Topic Author
27 Feb 2025 20:25
#909486
Can anyone tell me what fluid to use in the needle damper of Nippon Denso speedo and tachos.  Thanks
  • asphalt900
  • asphalt900's Avatar
Re: Speedo/Tacho damper fluid
28 Feb 2025 13:22
#909502
A good start is 100K CST silicone differential fluid. If You want a slower return to Zero try 200K. Note Tachs and Speedos have different drive units and spacing between mechanisms. Same for Seiki.
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
01 Mar 2025 07:36
#909520
Silicone oil/grease seems like the right type of fluid, but I was curious if you could find silicone oil specifically made for damping.
A quick google search turned up two uses that seems pretty common.  Damping fluid made for turntable tonearms, and damping fluid made for RC car shock absorbers.
It seems likely that the tonearm damping fluid could be a good place to start.
Also, this place has a range of viscosities.   www.clearcoproducts.com/silicone-damping-fluids/
My dad's '74 Z1
'00 ZRX1100
  • asphalt900
01 Mar 2025 08:13
#909522
DOHC, that's exactly what i've been using for 15+yrs doing these gauges. You want a "tacky" fluid, NOT oil. I use a product called "Factory Team", in different viscosities. Actually rumor has it a subdivision of Lucus Oils. I'd never thought of record player fluid but i'd bet it's similar. Probably the same fluid used in multiple things that you'd want damping.
  • Cra-z1
  • Cra-z1's Avatar
02 Apr 2025 07:36
#910850
I took asphalt's suggestion and went with 100k cut fluid and seems to work great. You probably have a RC car shop close to you that sells it for the differential on the cars. That's where I got mine from.
  • asphalt900
02 Apr 2025 09:01
#910858
Excellent Crazy, glad, finally someone took the initiative to try what I've been touting for years!
  • Nessism
  • Nessism's Avatar
02 Apr 2025 13:57
#910876
Does anyone have a photo showing where to inject the fluid?  The needles on my 750 tach and speedo both wobble.
  • Cra-z1
  • Cra-z1's Avatar
02 Apr 2025 19:11 - 02 Apr 2025 19:21
#910883
I had a whole thread on it. I will see if I can find it. In general I drilled the hole in the back of the cup about 3/4 up from the bottom.
Search for (bored so working on gages) in Technical forums
Last edit: 02 Apr 2025 19:21 by Cra-z1.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
02 Apr 2025 23:23
#910886
Bored so working on gages - KZRider Forum - KZRider, KZ, Z1 & Z Motorcycle Enthusiast's Forum
