Z1r rear wheel? Help
  • ronnieV
  • ronnieV's Avatar Topic Author
10 Sep 2024 10:50
#904188
Hey guys. I picked up a rear wheel I'm told is a z1r wheel. It's 18inch with what looks like 3 valve stems.
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
Re: Z1r rear wheel? Help
10 Sep 2024 11:01 - 11 Sep 2024 05:19
#904189
Do you have a specific question?
Yes, that could be a Z1R wheel.  It's 18" and has a 4-bolt rotor.  The drill pattern suggests the rotor is from a '79 or '80 model.
This wheel came with an inner tube and bead locks.  There are two holes for the bead locks, and one for the inner tube valve stem.  I'm guessing someone decided to run without a tube, and used 3 valve stems to plug all the holes.
My dad's '74 Z1
'00 ZRX1100
Last edit: 11 Sep 2024 05:19 by DOHC.
The following user(s) said Thank You: ronnieV
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
10 Sep 2024 11:34
#904190
Agree with DOHC, at least that is what it looks like to me. Can see tubeless on the tire.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • ronnieV
10 Sep 2024 15:54
#904200
I just wanted to verify if it was a z1r wheel in case I decide to list it for sale.
  • sf4t7
  • sf4t7's Avatar
10 Sep 2024 20:43
#904207
This message contains secure information
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • ronnieV
11 Sep 2024 03:55
#904209
  • DOHC
  • DOHC's Avatar
11 Sep 2024 05:57
#904211
Assuming this is a KZ1000 wheel, I believe the '78 and '80 Z1R used the same rear wheel as the '79 and '80 KZ1000A Mk2.  So you could advertise it as correct for either bike.
The KZ650C had a cast 18" rear wheel, but I believe used a smaller axle.  If this fits the larger KZ1000 axle, it's probably a KZ1000 wheel.
If you peek under the brake rotor, you should see a date stamp cast into the wheel.  The wheel I have matches pretty closely the date stamp on the frame.  For my '78 Z1R, the frame and wheel are both dated 11/77.
My dad's '74 Z1
'00 ZRX1100
  • ronnieV
11 Sep 2024 11:41
#904216
So would this be a 78 wheel?
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
11 Sep 2024 12:36
#904217
8/8/77 would be "78 model year" (post shut down model year change June/July)
  • DOHC
  • DOHC's Avatar
11 Sep 2024 13:11 - 11 Sep 2024 13:21
#904218
I agree.  And I believe the only 1978 kz1000 model with a cast 18" rear wheel would be the Z1R.
But it still has the later brake rotor as well as the later rotor bolts (flanged bolts with no lock tabs).
Edit:  The '78 kz1000 police model also had an 18" cast rear, but it's a different part number and the edge of the wheel has a different lip shape.
My dad's '74 Z1
'00 ZRX1100
Last edit: 11 Sep 2024 13:21 by DOHC.
  • ronnieV
12 Sep 2024 05:56
#904252
I was told he added the rotor but again can't say for sure .
  • sf4t7
  • sf4t7's Avatar
24 Sep 2024 21:37
#904587
Hey Ron,
I see you replied to my PM a while ago.  I can't figure out how to read it (old guy vs computers!)
Moderator - please forward my email address to ronnieV.  Thanks
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
