Can you chop a chrome fender?
- hat0791
22 Nov 2005 08:35
I was wondering, how dificult would it be to cut down the front fender on my '79 1000ST?
It has the big stock chrome fender, and I'm going for somthing a little more cafe' styled.
Any suggestions?
Any suggestions?
- hat0791
Re: Can you chop a chrome fender?
22 Nov 2005 08:41Please Log in or Create an account to join the conversation.
- cudaosix
22 Nov 2005 08:43
How about, swapping fenders with the shorter LTD type and keep your current fender in case you want it later. The short LTD front fenders look great.
Yeah, thats a nice looking front fender you have there, I'd keep from cutting it.
Post edited by: cudaosix, at: 2005/11/22 11:45
Post edited by: cudaosix, at: 2005/11/22 11:46
- hat0791
22 Nov 2005 08:46
How much would one of those cost on Ebay?
(I'd look myself, but I'm blocked from it here at work.
- cudaosix
22 Nov 2005 08:50
Not sure, I'll take a look to see if theres any on there now and post a link if I find one.
Post edited by: cudaosix, at: 2005/11/22 11:51
- cudaosix
22 Nov 2005 08:57
This is what I found on a quick search.
cgi.ebay.com/ebaymotors/FRONT-FENDERS-FO...dZ1QQsspagenameZWD1V
Are they chrome? I cant tell.
To answer your question. Yes you can chop a chrome fender, I havent tried but have seen a couple of bikes here that have. I imagine with the right cutting tool it isnt that difficult.
Post edited by: cudaosix, at: 2005/11/22 12:11
- sigep628
23 Nov 2005 15:08
I''m thinking of doing mine and painting it flat black like the rest of the bike. If I do I will take pictures and post them.
- 1045
23 Nov 2005 15:43
Yes you can, I did mine. I cut it with a die grinder and cutoff wheel and finished with a file and sandpaper to get to final shape and remove sharp edges. This is the important part,if you are going to paint it, then bead blasting with glass media to rough up the surface so the primer and paint will stick is a must. If you are leaving it chrome then I would do all the cutting with hand tools (hacksaw, file) as not to overheat the metal in the area around the cut and cause the chrome to turn blue or flake off..The edges will have to be touched up with paint so they won't rust.. Hope this helps
1045
1045
1045
- hydrolazer
24 Nov 2005 16:31
i just saw a couple on ebay just now,,one is at 22.50 and no bids on the other
\'79 kaw 1000 ltd
- sigep628
03 Dec 2005 18:07
here is what I did with my stock chrome fender. I have built a bobber style bike so this is probably not what you are looking for but I thought it was easy to do.
- sigep628
