Gas tank cleaning?
  • yeperra
  • yeperra's Avatar Topic Author
Gas tank cleaning?
18 Nov 2006 19:47
#93032
This is my first post here at the site. I read a post somewhere about a guy who cleaned light rust inside his tank using acid with small nuts inside and used some other liquid to coat the metal inside to prevent rusting. I'm not talking the cream stuff it was some chemical conversion process. Anyone have any ideas or know of the artical? I just can't find it, and it sounded pretty good.
  • tellietubbie
  • tellietubbie's Avatar
Re: Gas tank cleaning?
18 Nov 2006 20:08
#93040
After hydrochloric acid + nuts, anything containing Phosphoric acid.This creates a layer of Iron Phosphate on the steel and prevents rusting.
  • agawam
  • agawam's Avatar
18 Nov 2006 20:56
#93049
www3.telus.net/public/aschoepp/electrolyticrust.html read this I have cleaned several tanks(4) this way seems to work well, it took several days and I had to keep cleaning off the electrode from rust build up, I used a 10 amp battery charger.
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
19 Nov 2006 06:13
#93101
First, welcome!
Second..... I have done both the electrolysis and phosphoric acid methods (last year). These methods both worked well in removing rust, as long as there is no "gunk" in the tank. If there is any gunk, like gummed-up fuel or whatnot, niether method will work, and the the gunk will actually protect the rust underneath it from the acid or electrolysis.
This winter I am going to try the BBs in the dryer method. I've read other riders have such great success with no chemicals and mess. And it cleans everything in the tank, not just rust.
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
19 Nov 2006 06:14
#93102
Hey yeperra,
I tried the electrical method but couldn't really tell if I was accomplishing anything.
Why don't you read my article in the "Articles" section. I believe it's called "Rusty Tanks".
Good Luck
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • OKC_Kent
  • OKC_Kent's Avatar
19 Nov 2006 07:33
#93121
Here is my article in the Filebase. I use phosphoric Acid.
How to clean a rusty fuel tank
Cashion, OK
78 KZ650 B2 85,000+ miles
  • JMKZHI
  • JMKZHI's Avatar
Re: .
19 Nov 2006 07:50 - 03 Dec 2008 11:31
#93130
del
Last edit: 03 Dec 2008 11:31 by JMKZHI.
  • yeperra
19 Nov 2006 08:35
#93139
WOW! Thanks for all the help guys. This is the best forum I'v ever posted in. I now beleive I have enough information to really make a mess. I'm going to read up on all this and try to make a decision. As soon as I get my frame back and start the rebuilding I'll put up some pictures.
Thanks again!
Yon Perras
  • heartless
  • heartless's Avatar
19 Nov 2006 19:39
#93323
i used this method on my tank - it works VERY well. no signs of re-rusting after nearly a year.
  • KZ_Rage
  • KZ_Rage's Avatar
  • Kentucky Bourbon Barrel Ale
19 Nov 2006 21:21
#93353
Evapo-Rust looks like light duty only stuff from the reviews I've seen. $20+ a gallon for it is what I'm hearing.
OKC's way will work, give it a try.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
  • JMKZHI
  • JMKZHI's Avatar
Re: .
20 Nov 2006 05:35 - 03 Dec 2008 11:30
#93409
del
Last edit: 03 Dec 2008 11:30 by JMKZHI.
