belly pan
  • sbjones
  • sbjones's Avatar Topic Author
belly pan
17 Nov 2006 01:42
#92725
i am looking for a belly pan that would fit my 78kz650. i need one for racing.
if anyone has one, i would like to see one on a bike first. and if any one knows where i could get one. that would be great
thanks
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: belly pan
17 Nov 2006 19:58
#92880
Do you mean a Chin Scoop?
I bought mine on ebay, from a Honda VF500. The VF750s and VF1000s have a similar one. Just a little trimming to fit around the exhaust and it was ready to go.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • sbjones
Re: belly pan
19 Nov 2006 22:34
#93373
i was told by my local racing org that i needed to have a belly pan that could catch the oil if anything were to fail.
this is what i am talking about. does any racers have any experience with this.
rstnick, thank for the info. i maybeable to make something like that work for me.
  • donthekawguy
  • donthekawguy's Avatar
Re: belly pan
20 Nov 2006 01:18
#93393
You need a diaper. You can find one for a busa at schnitzracing.com.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • kawtoy
  • kawtoy's Avatar
Re: belly pan
21 Nov 2006 05:57
#93689
I have seen a lot of the diapers on ebay sell in the $100-150 range. I doubt that they would let you run with just a chin scoop. Scoops only cover the front part of the header and maybe about 6 inches underneath. You need something that will cover the whole motor so a racing diaper would be your best bet.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
  • dutchz
  • dutchz's Avatar
Re: belly pan
21 Nov 2006 08:57
#93733
Like kawtoy and don said, you need an oil containment pan. You will probably have to fabricate or modify something, because these are not readily available for vintage bikes. Turkey basters ziptied to the bottom or shoved in between lowers are a popular make-shift fix. I'll do some searchin...
1974 Kawasaki Z1
Stock front hub and rear axle.
  • 77KZ650
  • 77KZ650's Avatar
Re: belly pan
22 Nov 2006 14:08
#94099
in the sept(06) issue of "streetfighters" mag, theres a cool looking fireblade with a bellypan, but not much else for fairings. you might be able to modify one to fit
Scott
07 MDP Rookie of the Year
  • sbjones
Re: belly pan
27 Nov 2006 00:40
#95278
i don't get that mag. could you try and post a pic for me?
thanks
  • 77KZ650
  • 77KZ650's Avatar
Re: belly pan
27 Nov 2006 16:34
#95419
Ill have to get a pic of the pic, then Ill post it
  • dutchz
  • dutchz's Avatar
Re: belly pan
28 Nov 2006 15:48
#95743
Just some follow up... Browsed around a bit for you, I'm thinking maybe this may be made to work. It's for an EX500 originally, and it's dammed in the back. Can you measure approximately how wide and how long you need it to be?
1974 Kawasaki Z1
  • sbjones
Re: belly pan
29 Nov 2006 01:38
#95888
i chatted with a guy from the local track today. he gave me the info on the ex500 also, but he couldn't remember what size bike it was on . he thought maybe a 200.
so i am still looking at this point in time. any pics or anything like that would be helpfull
thanks to allB)
  • dutchz
  • dutchz's Avatar
Re: belly pan
29 Nov 2006 09:12
#95961
I can pull out the mold to see how long and wide it is. It's fiberglass so it's easily modified.
What width and length are you looking at on your bike to clear the exhaust system and the front of the engine / headers?
1974 Kawasaki Z1
