I need a GSXR750 fender (for a Kawasaki!)
  • Fossil
  • Fossil's Avatar Topic Author
07 Nov 2006 15:38
#90305
...'96 - '99. Does anybody know if the 600 or 1000 fenders of the same years are interchangeable?
edit - aw nuts, I thought I was in the bodywork forum - can this be moved please
Post edited by: Fossil, at: 2006/11/07 18:40
  • steell
  • steell's Avatar
Re: I need a GSXR750 fender (for a Kawasaki!)
07 Nov 2006 16:40
#90325
It's moved :)
  • sbjones
  • sbjones's Avatar
08 Nov 2006 00:41
#90425
i would go to bike bandit to find out if they are the same. or even go to dennis kirk and check out the numbers there.
good luck
  • wiredgeorge
  • wiredgeorge's Avatar
08 Nov 2006 06:00
#90444
Without knowing WHY you need this fender, I just wanted to point out that JPCycles.com sells LOTS of plastic fenders in various widths... I have used them several times rather than steel fenders. I think Denniskirk.com sells a couple as well. You have to drill the mount holes on most of them so they are pretty universal. I am currently repainting the bike in the pic... note the front fender. Was under $50 from JPCycles as I recall.
Post edited by: wiredgeorge, at: 2006/11/08 09:05
  • Fossil
08 Nov 2006 13:31
#90534
sbjones, I will try that and compare #s to see which are interchangeable. wiredgeorge, thanks but the idea is to find a good used one CHEAP, the why, GSXR front end on the GPz.
