mirrors: is there a secret?
- Bicycle Lee
02 Nov 2006 22:10
so I got a new pair of mirrors for my bike and they look great...only problem is I can't tighten them as far as I need to...and if I loosen them to where I can see, they're way too loose. Any secret?
1978 KZ1000 police
- Mikes82KZ1100
Re: mirrors: is there a secret?
02 Nov 2006 22:17
I'm guessing you are talking about screwing the mirror stud into the bars. If so, try screwing a thin nut onto the mirror stud then screw the stud into the mount. When you get close and have the mirrors adjusted where you want them then tighten the nut against the mount.
- The Gringo
- ¡Usted no necesita otra motocicleta!
03 Nov 2006 04:54
If you have new mirrors you should already have an adjustment nut on them. With the mirrors off the bike try unscrewing the nut with a wrench while holding the mirror shaft. Once you have it loose re-install the mirror and then use the nut to lock it down to the desired position.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- JMKZHI
Last edit: 03 Dec 2008 16:38 by JMKZHI.
- wiredgeorge
03 Nov 2006 05:45
I don't get the comment regarding tightening the mirrors and seeing out of them. I guess what you are asking is how to get the mirrors in position and tight. I think folks have explained that in that you just put the 10mm mirror in the 10mm thread and screw it in... You don't tighten the mirror in the socket you just screw it in to where it seems to stop then turn it back to where you can see and then use the lock nut to tighten the mirror.
- floridamba
03 Nov 2006 06:05
If your mirrors buzz when riding, JC Whitney sells a chrome and rubber device that screws between the mirror and handlebars. It has a rubber insert that helps reduce the vibration in the mirrors.
- wiredgeorge
03 Nov 2006 10:54
It has been my experience that the JCW inserts don't help. To reduce buzz, get convex mirrors. Also, better mirrors are mounted in their shells with more isolation and seem to not buzz as much. In the denniskirk.com catalog, there are generic replica mirrors. These buzz big time. There are Sean (can recall mirrors) and Napoleon mirrors and both of these are far superior. I have both types.
- Bicycle Lee
04 Nov 2006 11:42
I figured it out...having bought older mirrors, the screw end was stuck. I just lubed it up a little and got them to spin and solve my problem.
1978 KZ1000 police
- ambergrismooon
04 Nov 2006 11:58
JC Whitney rubber never helped mine. I now buy Napoleon also. In fact my Triumph has Bar-end Naps and are very clear. I thought for sure they were going to be buzzy being so far out on the bars but the are my clearest mirrors.
