Old 1980 vetter windjammer molding-windscreen
- Duck
- e vica na i sau na ga
11 Oct 2005 15:10
Have an old Vetter Windjammer and wonder what you guys have found successful for polishing scratches in the polycarbonate AKA Lexan AKA Plexiglas windscreen?
Also wonder if anyone has found a molding that works well and doesn't cost as much as the stuff from craigvetter.com
Thanks,
-Duck
Thanks,
-Duck
- John68
Re: Old 1980 vetter windjammer molding-windscreen
11 Oct 2005 17:19
try 3500 grit wetsanding, then use 3M Perfect-It II on a foam waffle buffing pad, do not exceed 1400 rpm with the buffer and keep it moving. also, do not let the rubbing compound dry on the windscreen, just buff until it starts to get a light haze, and then wipe off with a microfibre towel. allowing the foam pad to dry out the compound will make more scratches than it will remove. Let me know how it turns out.
- BSKZ650
12 Oct 2005 05:35
I have a friend who found some aftermarket molding on e bay, it is not near the quality of the stuff form vetter, I stepped up to the plate on mine
77 ltd1000, current rider
76 kz900, just waiting
