Almost finished
  • mjansen4
  • mjansen4's Avatar Topic Author
Re: Almost finished
30 Aug 2006 09:46
#73419
A new set of tires is on the list of things to do before riding. Those have been sitting since 1991 I think.
1977 KZ650B1 - Mostly stock except for some appearance mods.
  • cnyl
  • cnyl's Avatar
Re: Almost finished
30 Aug 2006 11:57
#73439
kawtoy wrote:
Is that a right side fork lower I see on the left side? Bike looks pretty cool. Here is a phrase you will never hear. "Sorry I hit you. I didn't see or hear you coming"
It looks like a left side lower put on the right side.
:P Kinda looks like they need to be reversed. Sould'nt the caliper be behind the fork when rolling forward?
Post edited by: cnyl, at: 2006/08/30 14:59
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
  • cnyl
  • cnyl's Avatar
Re: Almost finished
30 Aug 2006 12:04
#73442
After looking again.. I guess that's the only way to mount the fender.
Great job on the engine. Did you sand it down first? What kind of paint did you use?
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
  • OnkelB
  • OnkelB's Avatar
Re: Almost finished
30 Aug 2006 15:22
#73477
:P Kinda looks like they need to be reversed. Sould'nt the caliper be behind the fork when rolling forward?<br><br>Post edited by: cnyl, at: 2006/08/30 14:59
77 650 B1 is born like that - single caliper mounted in front of the fork leg. 78 B2 has single caliper mounted behind the front leg, rest of the 650s except for the H (CSR) models have twin calipers mounted behind the fork legs.
77 KZ 650 B1, 82 GPz 1100 B2.
  • kawsakiman
  • kawsakiman's Avatar
Re: Almost finished
30 Aug 2006 15:30
#73479
you know what? if it was only $50 and it runs, it was a beauty before you even did anything. nice to see one more was saved from a slow painful death.
  • ambergrismooon
  • ambergrismooon's Avatar
Re: Almost finished
30 Aug 2006 16:21
#73503
It's my understanding that the 900 forks are like that too. The 76 900 LTD came with the calipers mounted behind the forks. This was OK because the front fender was a shortie and didn't use the lower brace. But this also caused a little problem bleeding because of the position of the bleeder. It was tilted down and the air was reluctant to come out. I decided I wanted a full painted fender on mine so I went to a 650 SR fender. I reversed the forks so I had the fender boss pointing to the back for the fender brace. This also put my calipers to the front of the fork which positions the bleeders in a up position. I believe the 900LTD suppliment book mentions this.
And I think that Tangelo color is cool!
Post edited by: ambergrismooon, at: 2006/08/30 19:23
  • Snakebyte
  • Snakebyte's Avatar
Re: Almost finished
31 Aug 2006 10:07
#73664
Bikes l@@kin good. Ilike that color:woohoo:
  • mjansen4
Re: Almost finished
31 Aug 2006 10:22
#73668
I washed the engine with oven cleaner, gave it a real good rinse, let it dry in the sun, and then painted it with Plasticoat Engine Enamel. I glad everyone likes the paint. I agonized for about 6 months over what color I was going to use. Thanks for all the feedback! I'll get more pictures when I get all the parts on it.
Post edited by: mjansen4, at: 2006/08/31 13:25
  • dans77cafe
  • dans77cafe's Avatar
Re: Almost finished
01 Sep 2006 20:00
#73985
I have a 1977 KZ650 with an aluminum rims and two disk breaks both in front of the forks.
  • 77KZ
  • 77KZ's Avatar
Re: Almost finished
01 Sep 2006 20:25
#73989
Great job!! Thought about painting my lowers and after seeing yours I just may. Can't wait to see the finished project. Damn you got that for $50 less than I paid for my 78.
"What do you mean we can't change the alphabet to W,X,Y,K,Z!"
Western, OH, Formerly... Western, NY
1978 KZ650B, 1979 KZ650C, 1978 KZ750B, 1982 KZ750 LTD, 2006 ZX-6R, 2009 Ural Gear Up, 1974 Yamaha DT360 (It's Green Anyway!)
  • mjansen4
Re: Almost finished
05 Sep 2006 10:40
#74642
OK, here it is. The only thing missing is the front brake caliper and master cylinder which I will be rebuilding shortly...
  • mjansen4
Re: Almost finished
05 Sep 2006 10:41
#74643
