Luggage rack for 82 KZ750N1?
- ScottZ
18 Aug 2006 20:46
Just wondering if there are any direct fit racks for my new Spectre so I can carry some gear from time to time. Any help would be appreciated
- ScottZ
Re: Luggage rack for 82 KZ750N1?
19 Aug 2006 09:57
Any luggage advice in general for this model? It looks like I would have to relocate the turn signals in order to use saddlebags, and fabricate some supports also. A tank bag wouldn't be big enough for runs to the grocery store and I really don't want to take up passenger space by strapping a bag there. Any ideas?
- oldcoldankles
19 Aug 2006 11:42
This is what you need to look for Scott. This rack fits my KZ550 and replaces the grab bar. It looks like it could also be adapted to other KZ's with a little welding and chroming.
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
1981 KZ1000 CSR M1
1989 Corvette coupe
- ScottZ
20 Aug 2006 12:48
Has anyone used saddlebas on a Spectre? It looks like the turn signals would have to be relocated. Anyone done this? Where is a good place to mount them, or would it be better to get an aftermarket setup? I really don't like the enormous fugly brakelight either.
- Mikes82KZ1100
20 Aug 2006 19:19
The 1100 I just bought had a rack/backrest on it. I removed the turn signals and mounted them to the rack so I too could have clearence for saddlebags. I agree, it looks like the bags will need a brace to keep them from rubbing the shocks. I think a piece of 1" wide flat stock bolted to the rack mount should work. I'll try and post a pic. tomorrow of the relocated lights and bags.
- heartless
21 Aug 2006 05:52Please Log in or Create an account to join the conversation.
- Mikes82KZ1100
21 Aug 2006 06:52Please Log in or Create an account to join the conversation.
- ScottZ
21 Aug 2006 15:54
Looks like I need a rack like that one. Thanks for the info!
- ScottZ
21 Aug 2006 17:07
One thing I am considering is drilling thru the large taillight mount and bolting the turn signals to it so that it becomes an all-in-one unit. Anyone have any comments on that idea? I'd probably have to splice in about a foot or so more wire, but it would make room for saddlebags. Either that or just replace the taillight with something smaller that has turn signals attached. I don't believe turn signals are even required in Colorado.
Post edited by: ScottZ, at: 2006/08/21 20:08
Post edited by: ScottZ, at: 2006/08/22 09:18
- Mikes82KZ1100
21 Aug 2006 22:23
Maybe do something like this one. I can't remember where I got the pic., Maybe on this site. I just know I like the looks.
Post edited by: Mikes82KZ1100, at: 2006/08/22 01:26
- jordash
09 May 2010 21:40
Can I revive a thread this old? Is that even allowed?
I have a few unanswered questions here. I've relocated my taillights, but I'm not sure where to go for saddle bag supports.
I found nothing on ebay or the web for any terms I could think of searching, so I've come here.
Any help would be greatly appreciated, and here's a photo for good luck.
'08 KLR650
'82 KZ(Z)750 Spectre
In Denver, CO - Seeking nomad's land
- JMKZHI
10 May 2010 08:11
An old K&G universal luggage rack would be the most readily available & easiest to mount. The forward shock mounts slide in & out for forward/back adjustment while the front rear of the rack is adjustable for the width. You'll probably have to fab up brackets where they connect near the original turn signals. You'll have to remove the grab bar to install one. The KG racks are listed in all sorts of ways on ebbaayy: searching for Honda luggage rack usually yields the most results. Here's one:
