Removeing emblems???
- fdmc_99
15 Aug 2006 13:50
hi, just before i go and start to remove the emblems off of my tank and side covers is there any special thing i should know first?. im getting my bike painted and i dont want to screw espesially the tank up by removing the emblems. thnks guys...Francis
- Mcdroid
- Gone Kwackers
Re: Removeing emblems???
15 Aug 2006 14:00
Be particularly careful when taking off the side cover badges. They should be held on by metal push-on gizmos that fit on the emblem pegs. If you go roughly or quickly, you will break off those pegs...and then you'll be using double-side tape or something to re-attach the badges.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- ltdrider
15 Aug 2006 14:38
The tank emblems should be held on with tiny little phillips head screws. 2 on each side. Don't loose them. They're just the right length to hold your emblems, but not too long to puncture your gas tank.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- Robjb84
15 Aug 2006 15:43
Listen to ltdrider. Do NOT lose those screws then buy new ones and puncture your gas tank with them because they are too long. Seriously, dont do it. its STUPID...
But if you do, Seal All works great
But if you do, Seal All works great Please Log in or Create an account to join the conversation.
- JMKZHI
Last edit: 03 Dec 2008 18:42 by JMKZHI.
- fdmc_99
15 Aug 2006 17:25
ok thanks for all the info, far as i know i dont think i am puttin the tank emblems back on. so after i remove the emblems and the screws can i just cover the holes with filler?..i want to do most of the prep work as i can to save abit of money. thanks again guys
- kztee
- TeeRoy
15 Aug 2006 17:29
Love the idea about reattaching the side cover emblems by cutting threads and using lock nuts!! BTW - If any of you do loose the screws out of the tank emblems you can purchase a new set from Jeff @ Z1 Enterprises. Well worth the money compared to damaging your tank using the wrong screws!
1977 KZ 1000A - Currently rebuilding
1980 KZ 750 LTD - Mostly stock daily rider
1979 KZ 1000 LTD - Parts bike and/or future project
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
- Fourtoes
16 Aug 2006 03:40
So does no-one know where to get new push on retainers for the side badges?
Must be another way of attaching them!
- Kawozaki
- jkinney
08 Sep 2006 21:36
I have found some retaining nuts that are an exact duplicate, only problem is you pay $6.11 for 200 of them. They are at
www.mcmastercarr.com
and the part number is 94807A024 ;)
- letthegoodtimesroll
09 Sep 2006 05:38
I have also used silicone on the back of the studs and have had no problems.
1977 KZ650C1, Kerker Header, Dyna ignition and coils, GPZ 750 oil pan and cooler
- heartless
10 Sep 2006 05:58
Fourtoes wrote:
try your local Ace Hardware store.
