Sneek Peek
  • saltroni
  • saltroni's Avatar Topic Author
Sneek Peek
13 Apr 2025 18:54
#911267
I did a practice lay-out on my tank to figure out what goes where. If I can pull this off this summer    it should be the shizzzznits! Remember this is just practice taping. The blue tape is not right. The finish taping will be measured.
The following user(s) said Thank You: slmjim+Z1BEBE
  • kimchella
  • kimchella's Avatar
  • Away
Re: Sneek Peek
13 Apr 2025 21:05
#911270
Looking like a good scheme, look forward to the next episode with the base colour 😁
KZ650B1 frame number 225
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Sneek Peek
14 Apr 2025 13:40
#911304
Leaning by doing is the best DIY lesson and repeat, repeat, repeat rising the leaning level and skills.
Learning from mistakes leads to the final goal, just my 2 cents.
  • sf4t7
  • sf4t7's Avatar
Re: Sneek Peek
14 Apr 2025 13:51
#911305
+1 on that.  The mistakes make sure you remember what you learned!
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • Shankkole
  • Shankkole's Avatar
Re: Sneek Peek
15 Apr 2025 14:13
#911342
That is looooooking goooooood!
 Definitely post it up when that thing is sprayed and stripes are laid!
  • asphalt900
  • asphalt900's Avatar
Re: Sneek Peek
16 Apr 2025 03:04
#911354
That is one busy pinstriping scheme you have going on there for sure!
  • saltroni
Re: Sneek Peek
14 May 2025 10:58
#912429
I got a couple nice days without RAIN here in So Central Kentucky. The tank and side covers are in metal flake. Here are some pics.
I am not a painter but I play one in my garage!
  • z1kzonly
  • z1kzonly's Avatar
Re: Sneek Peek
15 May 2025 15:16
#912464
Good For You! I have always painted since 1980! I'm 67.
Looks like you already know it!
Just use a good urethane clear coat!!
None of the cheapest stuff online!
Good Luckl!
The following user(s) said Thank You: Gdizard, saltroni
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: Sneek Peek
15 May 2025 15:53
#912465
Not that it matters either way, but I have always found the hardest part of painting to be the prep work. Spraying paint out of a gun or a can has always been easy to me. The other part much harder!
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • saltroni
Re: Sneek Peek
18 May 2025 11:44
#912550
Thank you for all the comments. I am waithing for some candy black to do the shading. then its on!
The following user(s) said Thank You: Gdizard, Wookie58, kimchella
  • kimchella
  • Away
Re: Sneek Peek
18 May 2025 13:05
#912556
Coming along nicely, good job 👍
