Sneek Peek
- saltroni
Sneek Peek
13 Apr 2025 18:54
I did a practice lay-out on my tank to figure out what goes where. If I can pull this off this summer
it should be the shizzzznits! Remember this is just practice taping. The blue tape is not right. The finish taping will be measured.
The following user(s) said Thank You: slmjim+Z1BEBE
- kimchella
Re: Sneek Peek
13 Apr 2025 21:05
Looking like a good scheme, look forward to the next episode with the base colour 😁
KZ650B1 frame number 225
New Zealand
New Zealand
Re: Sneek Peek
14 Apr 2025 00:45
Look forward to seeing the end result
Re: Sneek Peek
14 Apr 2025 13:40
Leaning by doing is the best DIY lesson and repeat, repeat, repeat rising the leaning level and skills.
Learning from mistakes leads to the final goal, just my 2 cents.
- sf4t7
Re: Sneek Peek
14 Apr 2025 13:51
+1 on that. The mistakes make sure you remember what you learned!
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- Shankkole
Re: Sneek Peek
15 Apr 2025 14:13
That is looooooking goooooood!
Definitely post it up when that thing is sprayed and stripes are laid!
- asphalt900
Re: Sneek Peek
16 Apr 2025 03:04
That is one busy pinstriping scheme you have going on there for sure!
- saltroni
Re: Sneek Peek
14 May 2025 10:58
I got a couple nice days without RAIN here in So Central Kentucky. The tank and side covers are in metal flake. Here are some pics.
I am not a painter but I play one in my garage!
- z1kzonly
Re: Sneek Peek
15 May 2025 15:16
Good For You! I have always painted since 1980! I'm 67.
Looks like you already know it!
Just use a good urethane clear coat!!
None of the cheapest stuff online!
Good Luckl!
Good Luckl!
The following user(s) said Thank You: Gdizard, saltroni
- gd4now
- Denco where did you go?
Re: Sneek Peek
15 May 2025 15:53
Not that it matters either way, but I have always found the hardest part of painting to be the prep work. Spraying paint out of a gun or a can has always been easy to me. The other part much harder!
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- saltroni
Re: Sneek Peek
18 May 2025 11:44
The following user(s) said Thank You: Gdizard, Wookie58, kimchella
- kimchella
Re: Sneek Peek
18 May 2025 13:05
Coming along nicely, good job 👍
New Zealand
New Zealand
