Por15 tank liner removal
  • JohnA
  • JohnA's Avatar Topic Author
08 Apr 2025 13:37
#911113
Hello gents has anyone had any success stripping por15 tank liner out of a tank without ruining the paintwork and if they have could you tell me how you managed it. Unfortunately mine has started lifting and causing problems and the paintwork is still great,
Many thanks in advance John
  • Nessism
  • Nessism's Avatar
Re: Por15 tank liner removal
08 Apr 2025 14:07
#911115
You need a strong paint stripper, such as one with methylene chloride, to remove the liner.  This stuff will damage the tank paint pronto, if you get sloppy.  You should use low tack tape all over the outside surface of the tank, to protect the paint.  Don't take anything for granted, and if any stripper hits the tape, clean it immediately.
The following user(s) said Thank You: JohnA
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
08 Apr 2025 14:17
#911116
MEK = Methylethylketon, be carefull. Eats paint like nothing.....
  • JohnA
08 Apr 2025 15:05
#911121
Thanks very much for your replies iv'e located a product from frost automotive called tank strip will let you know how i get on,
  • Nessism
  • Nessism's Avatar
09 Apr 2025 06:05
#911141
When stripping, allow the tank to out gas (vent), otherwise pressure inside will pooch the tank sides outward.  Don't ask me how I know this...
