Does a Z1000ST fuel tank fit a GPZ1100B1 frame?
  • Bozo
  • Bozo's Avatar Topic Author
  • Ride it like u stole it
17 Apr 2024 20:40 - 17 Apr 2024 20:44
#897771
There is a perfect fuel tan for a Z1000ST selling, it looks like the GPZ1100B1 tank I have but if possible I'd like to get this verified, thanks in advance
UPDATE: I just took my tank off for comparison, it appears this has a different tap and the fuel guage is in a different spot.
Last edit: 17 Apr 2024 20:44 by Bozo.
  • BlackZ1R
  • BlackZ1R's Avatar
  • Kawasaki in my blood
Re: Does a Z1000ST fuel tank fit a GPZ1100B1 frame?
25 Apr 2024 21:24
#898126
Was going to say that it looks nothing like the B1 tank I have. How's the Z1-R running?
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
  • Bozo
22 Dec 2024 15:51
#907075
I know the reply is very late but I just noticed this post. My Z1r off the road at present, I have 2 x FJ1200 and a hybrid GPZ1100B1 with an 83 motor - I do think of the Z1r ride, maybe 2025. How is your Z1r?
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
22 Dec 2024 16:06
#907076
You need to measure between the rubber standoffs, up front and then back to the peg that holds everything. I can tell you that I suspect it may be different. But, get measurements from the seller and compare. The petcock and gauge locations should not cause an issue.
If you can get it to work, you'll luv the 5gal it can hold! I did on my 80' ST... ~250 miles on a tank!
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
  • RonKZ650
  • RonKZ650's Avatar
23 Dec 2024 19:39
#907108
The KZ1000ST tank will only fit the KZ1000ST which was only made in 1979 and 80. They worked long hours and planned extensively to made the ST an entirely different motorcycle. Everything was extra heavy duty, and not interchangeable with any other model. In 1981 when the KZ1100 shaft came out they went back to light duty on everything.
The following user(s) said Thank You: !Seymore
