Touch up paint for diamond dark green kz900
- Rolf1976_KZ900
31 Aug 2023 00:44 - 31 Aug 2023 00:51
I have some paintchip on my 1976kz900 diamond dark green. I tried the search function and found that kawasaki made a touchup paint for it ,but guess that is not possible to find.Is there a car or bike color that has a good match? I know the paint is a 3 step paintjob with silver under green tinted clearcoat . I can mix this color and use a airbrush painting silver and green clear over that ,but the problem is that the paint i use is acrylick made for modelkits
se picks and i dont know if i can use the spraymax 2k clear on top of the acrylick paint.Another question: i have notised the sidecovers have some orangepeel mostly where the kz900 emblem is placed. Was this how the paint sometimes came from factory? if notim thinking of wetsand and buff out the orangepeel ,but there is a great risk since i dont know how thick the clear is and also maybe it is a tinted clear that vould mess up the color totally.
]silver base k1000 kit.
se picks and i dont know if i can use the spraymax 2k clear on top of the acrylick paint.Another question: i have notised the sidecovers have some orangepeel mostly where the kz900 emblem is placed. Was this how the paint sometimes came from factory? if notim thinking of wetsand and buff out the orangepeel ,but there is a great risk since i dont know how thick the clear is and also maybe it is a tinted clear that vould mess up the color totally. ]silver base k1000 kit.
Last edit: 31 Aug 2023 00:51 by Rolf1976_KZ900. Reason: pictures
- Warren3200gt
Re: Touch up paint for diamond dark green kz900
31 Aug 2023 01:29 - 31 Aug 2023 01:35
There are no codes from Kawasaki, There is a company in the UK that supplies paints to original specs albeit they are now water based. RS Bikes paints.
www.rsbikepaint.com//en-gb/colours.php
They do touch up pots and will post globally.
There is probably a similar company in the USA if your that side of the pond.
Last edit: 31 Aug 2023 01:35 by Warren3200gt.
The following user(s) said Thank You: Rolf1976_KZ900
- Rolf1976_KZ900
31 Aug 2023 01:42
Ok thanks i will check it out .Im based in Norway by the way i will update my user profile. I once had a car that was painted boston green metallick that i think is close but when comparing it side by side to the kawasaki it may bee way off .
