Broken seat pan hooks
  • Michel3007
  • Michel3007's Avatar Topic Author
27 Sep 2022 11:13
#874679
Hi everyone,
I am about to replace the seat cover on my KZ400 B2 and I have a few of the pointy ends of the seat pan (these triangular hooks that you bend up and on which you pin the cover before bending them back down) that broke because of rust/age. I am thinking of using zip ties to attach the cover where these hooks are broken, as it will be hidden under the foam and cover. Has anyone ever done this or might have a better solution ?
Cheers,
KZ 750 H2 LTD 1981
GPZ750R1 1982
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: Broken seat pan hooks
27 Sep 2022 12:50
#874689
Thanks for sending me down a rabbit hole.  I knew I had seen the product in the past but could not remember where.  After a deep search I found it check out this link
www.pandkclassicbikes.co.uk/original-spike-strip
Not saying you should purchase it but may be you can create one for the missing points on your seat pan.  Pop rivet it to the pan?
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: kzstreetfighter71, Mikaw, calum, Michel3007
  • Michel3007
28 Sep 2022 00:35
#874722
Thank you Gd4now, that is exactly what I needed and sorry for the rabbit hole :D
I actually saw videos from this channel when investigating how to change my cover ! I was so close...
I will update once I have installed a spike strip.
KZ 750 H2 LTD 1981
GPZ750R1 1982
  • gd4now
  • gd4now's Avatar
28 Sep 2022 10:16
#874752
I did not word my response as well as I could have.  You most certainly did not send me down a rabbit hole.  I did that all on my own.  As I said I did recall seeing the info on the strips but could not for the life of me remember where.  I was unwilling to let it go and move on without diving down the hole to find it.
I look forward to seeing how it helps you solve the issue with the seat recover.
1977 KZ650 B1
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
29 Sep 2022 09:37
#874804
I used spike strips when I recovered the seat on my KZ.
Can't recall off hand where I bought them, but a search should bring something up.
[IMG
[IMG
[IMG
[IMG
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • gordone
  • gordone's Avatar
18 Oct 2022 15:38
#875686
Repair broken side covers, what stuff is good to use?
Project:
  • Gdailey2112
  • Gdailey2112's Avatar
  • 82 KZ1100D1
18 Oct 2022 17:04 - 18 Oct 2022 17:05
#875688
great work on the seat!
gordone - there's a great write-up in the "articles" section for repairing side covers.
1982 KZ1100D1
Last edit: 18 Oct 2022 17:05 by Gdailey2112.
  • Mikaw
  • Mikaw's Avatar
18 Oct 2022 17:11
#875689
Look here for repair technique
www.kzrider.com/forum/11-projects/617631...-82-begins?start=144
