1983 KZ 440 LTD Belt rear wheel swap
  • jorbabe
  • jorbabe's Avatar Topic Author
31 May 2022 07:44
#867940
Hi All,
I'm looking to swap in a larger rear than the 16" wheel this bike currently runs. Is anyone aware of another KZ that will fit, or is there a swingarm that will fit this frame?
Thanks!
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: 1983 KZ 440 LTD Belt rear wheel swap
31 May 2022 17:23
#867958
There are none.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • jorbabe
02 Jun 2022 09:23
#868043
I’m assuming I’d be looking at either a custom swingarm (and a wheel to match) or a custom hub (on the existing swingarm) and laced to a new rim?
  • TexasKZ
  • TexasKZ's Avatar
02 Jun 2022 10:37
#868048
Do you want a wider wheel or a larger diameter, or both? If you want to ditch the cast alloy wheels and replace them with wire spoke wheels, you are looking at some fairly extensive fabrication. Do you plan to convert the rear brake to a disc? Plans for the front brake or brakes? Will you convert to chain drive?
Finding hubs that are not too wide and will accept your stock axle diameter will help quite a bit.
How you proceed depends on what your ultimate goals are and how much fabrication you can do or are willing to pay for.
