which paint works best
- Gdizard
21 Feb 2022 10:09
Is anyone familiar with primers and paint?
I want to paint the clamps that go on the carb to intake port.
- z1kzonly
Re: which paint works best
21 Feb 2022 10:14
That olive drab coating was some type of anodizing. But are you looking for OEM restore? Correctness? Or just to coat and not rust?
Get like an Army olive green color in a urethane spray can, even have it mixed at a car auto paint business that mixes paint.
- Gdizard
21 Feb 2022 10:29
thank you
I wasn’t to make them look original and I want to learn how to pick the right type of paint.
21 Feb 2022 12:01
The olive drab clamps were actually zinc plating, with a final quick dip to get the colour. I've tried it and have not been successful.
If you're not concerned with correctness then I would suggest buying new clamps rather than painting. But if you want to go low cost you could strip the old ones and paint. Any paint would be acceptable. Just make sure the surface is clean of any oil before spraying.
- PoodlePuncher
05 Mar 2022 21:50 - 06 Mar 2022 09:47
you could try
cerakote
it's the powdercoating used on guns.
can purchase it in small quantities, and do it yourself at home.
'75 KZ400S & '81 XS1100
Last edit: 06 Mar 2022 09:47 by PoodlePuncher.
- howardhb
- God, I trust
08 Mar 2022 08:55
That "olive" color is a post zinc plating process, known as "passivation".
It is basically a "colorised" oxidation of the zinc plating. (Zinc typically oxides to an unattractive dull grey color)
The three colors I am familiar with are yellow (most popular), black and olive.
'81 GPz 550 D1
'82 Yamaha YB100 Fizzie
