fitment of early GPZ750 tank/tail/side covers on kz750
- Bubba_zanetti
28 Aug 2021 12:58 - 28 Aug 2021 13:01
I recently acquired a 1981 KZ750E, can a 1982 gpz750 or 1983 kz750 tank/tail/side covers fit on the 1981 kz750E without modification? are the frames and mount points the same across? thanks.
Last edit: 28 Aug 2021 13:01 by Bubba_zanetti.
Re: fitment of early GPZ750 tank/tail/side covers on kz750
28 Aug 2021 14:30 - 29 Aug 2021 07:02
Frames tend to vary. it depends.
You could compare the diagrams at Kawasaki.com or Partzilla. the drawings are fairly accurate. Partzilla is easier to use.
The 82 750-R1 body parts are different. I'd guess an R1 or L3 tank might work if you bend the rear mounting tab, but that is just a guess.
ps: are you just trying to make cosmetic changes or do you need parts?
Last edit: 29 Aug 2021 07:02 by martin_csr.
- Ojisan rider
29 Aug 2021 17:15 - 29 Aug 2021 17:19
From what I know, the tank have different rear mounting, and tail piece have different mounting as well so no, they won't fit without modification. Not sure about the side cover as I never wanted to replace mine (which is 82 GPz/KZ 750) so never look into it.
www.kzrider.com/forum/11-projects/606825...kz750-gpz-r1-project
You can reference the above site. My resurrection project and you can see the side cover and tail section.
82' KZ750-R1 cafe racer style. Clip-on, Rear set, Fork-Brace, Mikuni Flat-slide (forgot the size), Kerker.
84' GPz750 (basket case). everything are in pieces.
89' ZX750-H1 (ZX-7 Ninja). Resurrection project are on going with my KZ750. Everything is stock.
Last edit: 29 Aug 2021 17:19 by Ojisan rider.
