1978 Kz 1000 luminous red
  • harpereh
  • harpereh's Avatar Topic Author
12 Jan 2021 15:48
#841601
Well I cannot seem to find a paint code and was wondering if someone out there would happen to know or a modern day equivalent.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: 1978 Kz 1000 luminous red
13 Jan 2021 11:30
#841667
Dana doesn't share paint code formulas, but may be a source to consider for getting the work done.
www.facebook.com/WFOCustomPaint/photos/1...pain/236607989691183
1982 KZ1100-A2/1170 sleeper 😀
  • hardrockminer
  • hardrockminer's Avatar
13 Jan 2021 12:22
#841669
You could try Ralph at Paintworkz. He is the authority on Z1 paint.
  • martin_csr
  • martin_csr's Avatar
13 Jan 2021 15:11 - 13 Jan 2021 15:12
#841677
vintagemotorcyclepaint on EB has a few colors, but I don't know if either of the reds shown in his listings would be correct.
One is for a 1000 Ltd & the other for a 900 Ltd. In the description he mention Dana WFO.
I don't know anything about the seller or if he does special orders.
I found the guy by searching EB for Kawasaki Sundance Blue
Last edit: 13 Jan 2021 15:12 by martin_csr.
  • PaintWorkz
  • PaintWorkz's Avatar
15 Jan 2021 19:13
#841766
There are no codes from Kawaski to get paint mixed from. I sell a match for the 78 KZ1000 green but not the red. The red used a flesh / pink solid base coat, a silver flake mid coat, and a candy red top coat.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
  • Kaylinator
  • Kaylinator's Avatar
16 Jan 2021 17:00
#841836
Is the luminous green intended to be multistage? I've seen another seller from Europe that sells most as multistage, but sells the luminous green as single stage.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
  • PaintWorkz
16 Jan 2021 19:02 - 16 Jan 2021 19:05
#841841
The original factory 78 1000 green is a tri coat candy color also. It uses a metallic champagne base coat and a candy green top coat.....so a single stage would not be a very good match.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
Last edit: 16 Jan 2021 19:05 by PaintWorkz.
The following user(s) said Thank You: Kaylinator
