Ready for blasting build begin
  • weebeasty
  • weebeasty's Avatar Topic Author
08 Sep 2020 04:06
#834580
so decided to start on the 1000R2 needs lots of work
  • TexasKZ
  • TexasKZ's Avatar
Re: Ready for blasting build begin
08 Sep 2020 06:57 - 08 Sep 2020 06:58
#834590
I see that the R2 has some additional bracing along the backbone. Are there other differences between it and the other J-engined models of that time?
By the way, if you click a Insert All when posting pictures, they will show up full size in the post.
Last edit: 08 Sep 2020 06:58 by TexasKZ.
  • weebeasty
09 Sep 2020 04:40
#834644
thanks for pointing out the failure to upload properly... will try as i go to get it done right. (was using the phone to upload so I did not see it.
as for the bracing i have a GPz1100B the one in the avatar it has the same bracing as the R2 frame i have. on another note i am trying to find out if it really is a R2 frame as it is noted in the bike papers as a 1000R2 but frame number i s DZT104-000713 but stamped as KZT10R-000713. so it is a bit of a conundrum .
no matter will be sorted as things go
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
09 Sep 2020 10:36
#834655
Based on the ELR registry, the frame number KZT10R-000713 should be correct for a euro spec ELR.
Also, it looks like #713 would be a 1982 model, not an R2 as you mentioned.
www.kz1000r.com/index.php/frame-numbers-and-what-they-mean
My dad's '74 Z1
'00 ZRX1100
The following user(s) said Thank You: weebeasty
  • weebeasty
10 Sep 2020 02:48
#834708
much appreciated and good to know it is earlier makes the build all the more worth it for me
thanks for that :)
