1981 KZ440 LTD Belt Drive Belt Guard?
- ERIK814
22 Jul 2019 14:52
There is a rubber flap hanging down from the rear fender (sits between the rear wheel and engine). It has a tilt toward the belt and the rubber belt actually runs along it when the wheel spins. I didn't see anything in the owner's manual for it - any ideas? Is this thing necessary or can I take it out? I'll try to get a photograph later.
1981 KZ 440 LTD Belt Drive (Late Model)
Re: 1981 KZ440 LTD Belt Drive Belt Guard?
23 Jul 2019 05:27 - 23 Jul 2019 11:24
No eBay APP ID and/or Cert ID defined in Kunena configurationThe fender diagram at Partzilla for the 82 KZ440 Ltd Belt shows the fender flap & fender plate.
From the cross-reference there at partzilla the flap was used almost exclusively on belt drive models.
Kawasaki probably put it there for a reason, maybe to protect the belt or front pulley from road grit. ???
Since it seems crooked, I would try loosening the flap plate bolts & realign it. maybe put a light thread locker on the bolts.
If it can't be realigned, maybe trim the rubber or enlarge the bolt holes.
Just for comparison. here's a 440G rear inner fender w flap which is kind of chewed up.
Last edit: 23 Jul 2019 11:24 by martin_csr.
The following user(s) said Thank You: ERIK814
- ERIK814
23 Jul 2019 13:30
Thanks Martin. Mine is chewed up too and I think it may just be due to the design (rubber on rubber wears after a while). This is why I was wondering if I can take it off to help preserve the belt. But if it helps protect the belt or front pulley I'll just keep it on.
24 Jul 2019 05:24 - 24 Jul 2019 05:31
Just an FYI for future repair. When the time comes to replace the belt, you can convert the 440 to chain drive & it's a direct swap. The only thing I'm not sure about is whether or not the chain/belt guards swap.
Last edit: 24 Jul 2019 05:31 by martin_csr.
- ERIK814
24 Jul 2019 17:17
Thanks for the tip about the swap but for now I am trying to keep this thing as original as possible.
