Replacement gas tank 85 KZ700A-1
  • Motard916
  • Motard916's Avatar Topic Author
06 Mar 2019 12:29
#799827
I have a 85 kz700a-1 it is not quite a bobber yet, I intend on making it one. The gas tank itself is intact, no petcock and severe rusting. Have small holes starting to appear. I don't need a stock tank, would prefer one different, but would like coverage of top part of frame from trippletree to seat. Does anyone. Know what models and years will fit? I've spent a few hours on here searching , can't seem to find anything, so pardon me if it's here already. Is there any aftermarket options? I am new on this site. Any help appreciated. Love this site!
  • martin_csr
  • martin_csr's Avatar
Re: Replacement gas tank 85 KZ700A-1
06 Mar 2019 15:20 - 07 Mar 2019 06:02
#799838
Is the tank installed on the motorcycle? I'm wondering if you have the rear tank mount bracket.
As for other tanks >> direct fit would be the KZ700, KZ750-L3 & KZ750-R1 GPz. these might be hard to come by.
You might be able to use a KZ750E tank with some fettling of the rear mount, but I really don't know.
ps: a KZ700-A1 should be a 1984 model & I wouldn't cut up or ruin one of those.
Last edit: 07 Mar 2019 06:02 by martin_csr.
The following user(s) said Thank You: Motard916
  • Nessism
  • Nessism's Avatar
06 Mar 2019 18:46
#799841
For a bobber you may want to consider a 750 LTD tank. Some fabbing may be needed for the rear mount but it's a bobber so that shouldn't be an issue.
