KZ750N has 3-4 pinholes.
- JohnLuke
- 1982 KZ750N Spectre
20 Dec 2018 13:26
So I just found out that my 750 has pinholes in the tank. It doesn’t appear to be super rushed put I plan to fill the holes clean the tank then use some sort of coating.
Does anyone know what is the best way to fill the pinholes?
Thanks!
Thanks!
Re: KZ750N has 3-4 pinholes.
20 Dec 2018 14:01
Where are the pin holes located,(pics)?
You can solder and fill the holes with tin or coating the tank with POR15 which will do a sealing layer over upcoming pinholes.
20 Dec 2018 14:58
I had a tank like that and used Caswell's epoxy sealer after derusting. Caswell's is super thick and reinforces the metal nicely on tanks with rust and thin metal. I started off by soldering all pin holes but during the derusting process more pin holes appeared and I got sick of breaking out the torch so I switched over to sealing them with epoxy on the outside after that.
- JohnLuke
20 Dec 2018 17:06
About an inch from the bottom on the left side.
It also leaks from the emblem on the right. I’m gonna check it tomorrow.
- JohnLuke
- JohnLuke
20 Dec 2018 20:39
Here are the 3 holes. I have access to a Lincoln flux core welder. Could I clean up the area and then tack it the sand it off? No matter what I’m probably gonna red coat it.
21 Dec 2018 05:43 - 21 Dec 2018 05:46
There are probably several good coatings available, but preparation is the key. I would do additional tank prep prior to whatever prep chemicals a kit would have & I would probably use the stuff from Caswell or the KBS coating or West Systems epoxy.
Quote from the link below by Jeff.Saunders of Z1Enterprises.com: What I've used on tanks that you can't seal using Kreem or Por15 is a marine epoxy resin to line the tank. West systems marine resin epoxy. 105 resin and 205 hardener. This mix creates a hard shell inside the tank that's impervious to gasoline. Use a 5:1 mix. ... KZR topic: KZ 650 tank leaking behind badge - options?
Last edit: 21 Dec 2018 05:46 by martin_csr.
