Painting a new fuel tank
  • loneagle
  • loneagle's Avatar Topic Author
20 Aug 2018 11:51 - 20 Aug 2018 11:52
#789408
I just got a reproduction Z1 gas tank for my bike and was wondering if I should remove the primer they applied at the factory. The tank is made in Taiwan and I'm not sure if it's a decent quality primer. It looks like epoxy, but I could be wrong.
'78 Kawasaki KZ 1000
'02 Harley FXDWG
'16 Harley Street Glide
Last edit: 20 Aug 2018 11:52 by loneagle.
  • z1kzonly
  • z1kzonly's Avatar
Re: Painting a new fuel tank
20 Aug 2018 12:59
#789410
At Least Primer is better than bare metal with an oil coating like the cheap Harley chi-comm crap guys bring me to paint!
Just wet sand it down with 400-600 to start, it will show you the low & high spots. I always put some simple green in my water when I wet sand in beginning.
I seal first with some epoxy primer thinned 10% xtra. Then I use my high build urethane grade primer for wet sanding before color coat.
The following user(s) said Thank You: loneagle
  • Nessism
  • Nessism's Avatar
20 Aug 2018 13:36
#789411
I would strip off the shipping primer and start fresh. For my last project I used Transtar Epoxy primer and it worked nicely.
