Painting Chrome fender
  • fallrock
  • fallrock's Avatar Topic Author
10 May 2018 05:48
#783165
How do you paint a chrome fender Thanks for help
Mitch
  • Nessism
  • Nessism's Avatar
Re: Painting Chrome fender
10 May 2018 06:53
#783167
The smooth chrome needs some roughness or "tooth" so the paint can grab on. Best way is sandblasting with a sharp edge media such as aluminum oxide or similar. If you can't do that then rough up the metal with a DA sander and some 100 grit paper.
For paint, two part epoxy primer is best followed by a urethane topcoat. Failing that, use some rattle can etching primer and your choice of top coat that's compatible.
  • KzRoger
  • KzRoger's Avatar
  • 81 KZ1000 24k miles.
15 Jul 2018 10:06
#786985
I did a similar paint project with great results.
Sanded with 80 grit.
Primed with etch primer
Primed with 2pt auto primer
Sanded smooth
Base coat and clear.
It has held up good on my brother's bike for 4 years.
  • martin_csr
  • martin_csr's Avatar
15 Jul 2018 12:41 - 15 Jul 2018 12:42
#786995
FWIW. I painted the manifold crossover section of my muffler system with Rustoleum bar-b-que grill paint without sanding the chrome & it has held up quite well. no peeling or anything.
Before painting, after dremel wire wheeling with jeweler's brass wheels off of eb.
Rustoleum silver bar-b-que grill paint. I also painted the insides.
I just now looked at the paint & it still looks the same as this pic from last year.
Last edit: 15 Jul 2018 12:42 by martin_csr.
The following user(s) said Thank You: mopguy, Knucklehead
  • z19OO
  • z19OO's Avatar
03 Aug 2018 04:37
#788115
That turned out great martin!
1975 z1 900
1979 kz650b
