Z1r seat fit kz1000E
- kz650guy
24 Apr 2018 15:22
Anybody know if this will work they look the same I have a kz1000e and can not find a seat but I can find z1r seat also could I just use the pan from this aftermarket seat and use a z1r foam and cover
- z1kzonly
Re: Z1r seat fit kz1000E
24 Apr 2018 17:08
Those E1-E2 shaft drives were all different and by themselves! Kawasaki engineers & designers took a bath with them! The Frames were wider, the front end trip trees were wider, fork tubes are 41mm. Center stand is wider, side covers are all unique to that shaft. I buy those bikes for $400, $250. For the last 2 that I got. Only thing good on them is the MarkII engine case with crankshaft to use for dragbikes.
If that touring seat came on bike, Have that reupholstered. Z1R will not fit.
But if you have a nice running shaft, I am sure it is a good road bike for comfort. They all had touring fairings and bags. So they were not beat up on the street or dragstrip.
Not my thing. But some guys must love them.
JMO.
JMO.
- kz650guy
24 Apr 2018 17:23
Intresting I did pay 500 for this from original owner super low miles I've been told the carbs are vm28 with accelerator pump but they may be 26 I'll have to check later
- z19OO
27 May 2018 04:50
Not even close. The ST seat is even wider than the MKII which looks the same. I personally love the 79-80 shaft drives.
1975 z1 900
1979 kz650b
1979 kz650b
