2K SprayMax clear
- RLBuddi
2K SprayMax clear
13 Feb 2018 04:29
Is there more than one part number for this 2K Spraymax clear? I see Amazon lists "Gloss", "Glamour", and "High Gloss" ..........is the one that everyone is using here part #368-0061 ?? Please advise. Thanks!!!
Re: 2K SprayMax clear
13 Feb 2018 05:05 - 13 Feb 2018 05:10
66autocolor.com lists 2K Clear Coat High Gloss Glamour with the same part number you posted.
On the SprayMax website I'm seeing matt, semi-gloss & gloss. Gloss = 680061.
SprayMax seems to be a German company, so the number you're seeing is probably the Gloss part number used in the USA market.
But just to be sure, I would compare the other part numbers you've seen with the ones on the SprayMax site.
Last edit: 13 Feb 2018 05:10 by martin_csr.
The following user(s) said Thank You: RLBuddi
- Kidkawie
- I bleed premix
13 Feb 2018 07:08
Even with gloss on the bodywork you'll want to 2000 wetsand and polish.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
