Removing heavy tank rust
  • kz650guy
  • kz650guy's Avatar Topic Author
26 Jan 2018 16:58
#777840
Just for fun I put 3 gal of evaporust in a 76 900 tank I'll post a pic of befor and after to see how it does tank looks like it had sat with water in it
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
Re: Removing heavy tank rust
26 Jan 2018 18:42
#777844
Electrolysis would be another option. I used that on an XS650 tank that was about as bad and then finished it with Evapo-Rust. Came out like new...
Good luck,
Jim
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • Nessism
  • Nessism's Avatar
27 Jan 2018 04:51
#777859
Evaporust is great stuff. Only knock against it is the cost.
I use phosphoric acid. Kleenstrip Etch & Prep as sold by Home Depot for derusting. Works fast and reasonably safe.
  • kz650guy
31 Jan 2018 15:21 - 31 Jan 2018 15:23
#778094
Did one rinse out let it soak for 3 days and now I have a rust free tank I washed it out with water blew it with air compressor then put a half quart of transmission fluid in it for rust prevention very pleased the evapo rust was 13 dollars a gal at local rural king I saved what came out of tank for future use
Last edit: 31 Jan 2018 15:23 by kz650guy.
  • BlackZ1R
  • BlackZ1R's Avatar
  • Kawasaki in my blood
03 Feb 2018 21:08
#778167
Tank looks good. I've have great success using apple cider vinegar. Works great, inexpensive. Rotate tank every 24 hours until all surfaces have been treated. Drain, rinse, rinse with baking soda and water. Blow dry. You're good.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
  • Tyrell Corp
  • Tyrell Corp's Avatar
09 Feb 2018 10:45
#778420
I like to prep first with a length of dog lead chain or similar, with string attached for easy removal. Removing the sender and fuel level float first them give it a good shake It removes most of the loose rust.
The following user(s) said Thank You: RLBuddi
