KZ750 Spectre 1982
  • JohnLuke
  • JohnLuke's Avatar Topic Author
  • 1982 KZ750N Spectre
KZ750 Spectre 1982
13 Jan 2018 22:41
#777264
I plan on using POR 15 for the frame and maybe the wheels. But what paint should I use on the tank? I've been looking for months now and idk. I plan on the engine being black with polished side covers.
A close friend of mine mentioned Seymour. I trust his word, so I assume it's a nice paint. There are a lot of paints there. Can someone tell me the difference and which on is best for the engine?
1 - HOT SPOT® HI-HEAT RESISTANT PAINT
2 - Cast Blast
3 - HI-TECH® ENGINE ENAMELS
The guy said cast Blast but I assume he meant #3 engine enamel.
Any advice/opinion on it are welcome.
Thanks!
  • martin_csr
  • martin_csr's Avatar
Re: KZ750 Spectre 1982
14 Jan 2018 06:29
#777265
Assuming you plan on using rattle cans. On the fuel tank I would use an automotive paint, then for fuel resistance top coat with a 2k clear urethane, such as SprayMax, as gasoline attacks most if not all rattle can paints.
  • JohnLuke
14 Jan 2018 11:53
#777270
I plan on leaving the gas tank a brushed metal.
My question is about what paint I should use for the engine and the wheels, more so the engine.
Thanks!
  • Nessism
  • Nessism's Avatar
14 Jan 2018 11:55
#777271
Painting a gas tank is just like painting a car. There are various grades of paint available, with the higher grades providing better durability and gasoline spill protection.
High grade materials include epoxy primer for application on top of the clean metal, then use a base coat and urethane clear coat system. There are a lot of options available, with most being pretty good if you buy from a real automotive paint manufacturer. Dupont and PPG are a couple of leaders in the field, but there are some smaller guys that make good products as well.
Good luck
  • JohnLuke
14 Jan 2018 14:25
#777276
Yes, thank you. I'll keep that under consideration. What paint from the list of posted is used for a motorcycle engine?
2 - Cast Blast
www.seymourpaint.com/product-category/specialty/
