Paint don`t go off sodablasting
  • gordone
  • gordone's Avatar Topic Author
04 Nov 2017 10:26
#774214
Hi,
Today I tested soda blasting for first time, and it was not so efficient I hopped for, but it worked.
When I blasted the underside of the gas tank there was no problem removing the paint,
but on the other side I got problem... the soda is not able to remove the paint...
I tried to use sandpaper and it looks to be soft (the paint) when I got some temperture with the manual sanding the melted. so it made lumps. Please see attached picture... what todo know.. I have not access to sand blasting.
I was thinking fill the tank with water and use sandpaper on my grinder?
The special sandpiper for grinder have I used on other parts really nice and efficient... but I don`t know if I got problem
with sandpaper on these special paint?
1. Fill with water
2. Use my grinder with sandpapirer (not cut disc)
3. take out the water and dry the tank.
4. Use epoxy primer on the tank.
5. deliver it to a pro paint shop later. for painting.
Project:
  • retterath
  • retterath's Avatar
Re: Paint don`t go off sodablasting
04 Nov 2017 10:33
#774215
aircraft stripper.
  • gordone
04 Nov 2017 10:48
#774218
retterath wrote: aircraft stripper.
That is the sheet? it will take the paint and the primer and give me blank steel?
Project:
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
04 Nov 2017 12:37
#774225
Yep. Aircraft stripper will remove it all. Sometimes it can take more than one application.
I like to use it prior to bead blasting to make the paint easier to remove.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • gordone
05 Nov 2017 05:47
#774247
I diden`t find the same in Norway, but I have order now KLEAN STRIP PAINT REMOVER, hope that is doing the job also?
What to do after you have used the stripper, can you just use silicone remover and prime the surface?
Project:
  • jayrodoh
  • jayrodoh's Avatar
07 Nov 2017 08:15
#774295
Aircraft Paint Remover is made by Klean Strip, might be called something different over there. The Aircraft one is supposedly their strongest one. I've used it many times, especially good for removing clear coat on aluminum before polishing.
For prep, there are specifically made "pre prep" cleaners but you can use acetone as well prior to shooting primer.
1982 KZ750-M1 CSR
  • gordone
07 Nov 2017 23:18
#774331
Silicon remover is not strong enough?
I have not been able to get some good stripper in Norway (stringt rules) the company was empty in stock for Klean strip... so I needed to wait for 2-3 months for import....
So I have purchase one in the shop it was not so power full... I have been able to take of 2 layers in first round, and have now painted a second round and let it stay for 24 hours.... Hope I`m able to get the rest of.
See attached pictures.
Project:
  • martin_csr
  • martin_csr's Avatar
08 Nov 2017 05:52 - 08 Nov 2017 05:54
#774336
Are you going to repaint the tank? If so & since the old paint is so tough, why bother removing it? I was going to strip my fuel tank, but the original paint was like armor, so I just sanded it with emory cloth.
Last edit: 08 Nov 2017 05:54 by martin_csr.
  • gordone
08 Nov 2017 06:23
#774337
That is plan, but I wanted to check for corrotion, have fund some under the paint...
But know I will stop, remove what I`m able to today, and then prime it again...
Project:
  • martin_csr
08 Nov 2017 07:19 - 08 Nov 2017 07:20
#774339
If there's corrosion, then you probably ought to remove as much as possible so that you can thoroughly inspect the metal. My tank wasn't rusted at all, not even at the triple tree dings.
Last edit: 08 Nov 2017 07:20 by martin_csr.
  • Nessism
  • Nessism's Avatar
08 Nov 2017 09:17
#774341
Stripping off all the paint is a good idea. There is often spiderweb corrosion crawling under the old paint. The photos show an odd condition though, looks like plastic body putty under the paint. I'd keep going with the stripper and then move back to the media blasting to get all the remaining corrosion off from around the tank opening and on the underside. You need a perfectly clean metal situation if you want a lasting paint job.
  • gordone
09 Nov 2017 08:57
#774376
I found some corrosion under the original primer, so I`m glad I took of almost everything, it looks like the welding edge around on the tank is a critical area for corrosion.
I have sprayed 2k epoxy primer today.
Project:
