Painting Fr Br mc --- cap on or off?
  • martin_csr
  • martin_csr's Avatar Topic Author
18 Oct 2017 07:22 - 19 Oct 2017 06:01
#773215
Never mind. it was a goober type question. but I kind of split the difference & masked the reservoir, then put the cap on.
Reminders for future ref. brake caliper cleaner. self-etching primer.
VHT brake caliper paint. VHT flameproof. Eastwood 2k high heat paint.
duplicolor pdf -->> caliper paint -->> features/benefits -->> application tips -->> download file. when spraying over paint, scuff w RED Scuff pad or 600 grit.
89316009405511699000268269631773215
Last edit: 19 Oct 2017 06:01 by martin_csr.
  • bluej58
  • bluej58's Avatar
Re: Painting Fr Br mc --- cap on or off?
21 Oct 2017 05:45 - 21 Oct 2017 05:48
#773379
I have a 5/8 master cylinder that I hope to use for my next build, it works but I will rebuild it anyway.
The upper half is nylon I'm guessing? but very cloudy for lack of a better term.
The cap has prevented the brake fluid from getting on the outside for many years so I am looking for a solution for cleaning it up and maybe coating it with a product that is DOT-3 safe.
I read Somewhere that a 2 part epoxy clear coat might work.
78 KZ1000 A2A
Last edit: 21 Oct 2017 05:48 by bluej58.
  • martin_csr
21 Oct 2017 07:23 - 21 Oct 2017 07:32
#773381
Mine has a metal 1-piece body & metal cap. I've never heard of anyone painting a plastic mc, so you're on your own there. hee.
I baked the parts in the oven afterwards. The cap on this type of mc has a tendency to leak. Mine had a lot of hard crusty buildup on it, so I thoroughly cleaned up the reservoir & cap and will be installing a new diaphragm.
750 Ltd mc on left for comparison. mine had more caked on hard gunk that I hit with a brass wire wheel, but some of it required chiseling off in spots with an awl.
Last edit: 21 Oct 2017 07:32 by martin_csr.
The following user(s) said Thank You: JR
  • old_kaw
  • old_kaw's Avatar
21 Oct 2017 14:39 - 21 Oct 2017 14:40
#773402
martin_csr wrote: Mine has a metal 1-piece body & metal cap. I've never heard of anyone painting a plastic mc, so you're on your own there. hee.
That looks fantastic, Martin!
I looked for a new diaphragm for mine last week, but when I started seeing prices in the $50.00 range, I decided to wait on on the new diaphragm. Mine isn't leaking (yet), but last time I flushed the brake fluid (2 months ago), the rubber was pretty close to being mush, if you know what I mean. :-)
Where / who are you buying the new diaphragm from? I looked on Z1 and eBay, but was not finding what I want.
1981 Kawasaki Kz1000K1
Last edit: 21 Oct 2017 14:40 by old_kaw.
  • martin_csr
21 Oct 2017 16:30 - 21 Oct 2017 16:38
#773417
I got the diaphragm at the dealer several years ago, but it is now NLA.
What master cylinder is yours? It doesn't look like the 1000-A1 or A2 shown in the diagrams at Partzilla. maybe I'm mistaken.
Last edit: 21 Oct 2017 16:38 by martin_csr.
  • diamond
  • diamond's Avatar
22 Oct 2017 06:47
#773447
How did you restore the sight glass. Looks new. Great job.
Current bikes- 2010 HD street glide,2004 zrx1200r, 2001 wr290x,84 nija900A1 , 83kz750L3, mz250f.
Previously Enjoyed- 77 Kh400, 83 kdx175, 81 kz550, 84 ninja 900, 92 gsxr750, 2000 gsxr600, 02 R1,
01 yz250, 03 yz125, 06 R6, 00 cr125, 85 ninja 900, 07 Victory Jackpot, 83,84,89 RZ350,2006 rmz250
