Painting after Sodablasting
- gordone
02 Oct 2017 23:39
I`m gonne share my engine (take of the top for honing sylinders and overhaul the top), my plan was to sodaplast the whole engine before I start to divide the engine, good plan?
And when I`m finish rebuild the engine the plan was to paint it, but how should I prepare the engine before painting ?
Clean it with fat remover and dry it?
Is the order of doing things okay ?
Project:
Project:
Re: Painting after Sodablasting
03 Oct 2017 07:35
Painting the engine after assembly is the easy way. All the bolt heads will get painted though. The factory look involves painting before building the engine but that's a lot more work. Each piece needs to be carefully masked before paint. That's what I do.
Prior to paint/engine building washing all the parts in soap and water is advised. This gets all the dust and grit off.
- gordone
03 Oct 2017 08:36
I have a plan then
Thank you for feedback
Project:
Project:
